GaryParnell
Posted: Mon Dec 09, 2013 9:25 pm Post subject: |
I have a similar one, the problem is the mess, it either needs to be used outside; where you can get away with leaving the mess, or in a completely empty garage where it can all be swept up. The air needs to be bone dry as does the media otherwise it will keep clogging up!
Posted: Tue Dec 10, 2013 12:15 am Post subject: |
The other problem is the cost of suitable media, unless you live near a nice sandy beach  |
Rosco663
Posted: Tue Dec 10, 2013 3:29 am Post subject: |
Gary,
The practical tips on using this type of sandblaster are quite valid. I don't want to seem to be an old fun stopper but you also need to consider the safety aspects as well, particularly if you intend to use beach sand (silica sand). I found the following link which should help guide you through. Even better to do your blasting in a blasting cabinet or booth.
http://www.manleybros.com/safety2.htm
GaryParnell
Posted: Tue Dec 10, 2013 9:53 am Post subject: |
Thank your for your replies I have got a cabinet which is homemade and has an extractor, I also used glass as the media
Thanks very much
Gary Parnell |
