front lights
christine lowery
PostPosted: Fri Jul 11, 2014 6:01 pm    Post subject: front lights Reply with quote
hi gang
could all steam and vintage show visiters please keep a look out for this type of light that was original fitment to our royales in the early seventies [img][/img]
the one on the left is the one i require it is 3 inchs wide and 2 inchs high
and has 2 screw holes
a standard light is next to it
christine
PostPosted: Fri Jul 11, 2014 7:30 pm    Post subject: Reply with quote
Hi Christine,
Is this the same?
http://www.s-v-c.co.uk/product/l691-lucas-front-side-light--pair-/
christine lowery
PostPosted: Fri Jul 11, 2014 9:05 pm    Post subject: Reply with quote
thanks peter i will contact them for the size
christine
christine lowery
PostPosted: Fri Jul 11, 2014 9:08 pm    Post subject: Reply with quote
oops i see the size is marked at 83mm i wiil still contact as im on 75mmfor the lense and there size could be the overall size
christine Smile
Dalek63
PostPosted: Sat Jul 12, 2014 1:49 pm    Post subject: Reply with quote
Try a classic Land Rover supplier. I'm sure I have seen them on some series Land Rovers
sheffieldcortinacentre
PostPosted: Sun Jul 13, 2014 9:44 pm    Post subject: Reply with quote
one on right is series 3 land rover reverse light, also used on mini's as clear front indicators.
Cameron
PostPosted: Tue Jul 15, 2014 10:55 am    Post subject: Reply with quote
The one on the left is extremely rare. They were fitted to all Sprite caravans from around 1964 - 1966 and I've been looking for spares for months.
The new replacement Lucas lights (from a Hillman Imp) are the exact same size, but the lenses are less domed. Also, the light fitting on the back protrudes by an inch or so. If the caravan walls are wide enough, then it can be fitted, but most people will need to modify the Lucas lights to fit.
I have bought the Lucas lights to fit on my 1964 Sprite 400, be prepared to fork out for them though, they're £40 per set!
christine lowery
PostPosted: Tue Jul 15, 2014 1:27 pm    Post subject: Reply with quote
hi cameron
these lights were fitted to early 1970 royales for less than a year and had a white a lense and a flat chrome back(easy to solder new fittings onto)
the one in the photo i found in a box of bits at a caravan breakers
thank you for the information it is hard to build up the history of parts as most were sorced from suppliers who have long gone or don't have the records anymore
chris
Cameron
PostPosted: Tue Jul 15, 2014 6:45 pm    Post subject: Reply with quote
Hi Chris,
They were fitted to Sprites, as I said, from 1963/4 - 1966 and they had the matching indicators and brake/driving light units on the back too.
I have the name of the supplier on a new old stock pair that I found at an autojumble - will dig that out for you as a search point. As far as I know, they were cheap units bought by Sprite as they weren't expensive. Sadly they had a habit of the lenses going brittle and fading/breaking and the chrome bases rusting away.
The Lucas L961 is a very good match though - just like I said, they're not quite domed enough. But if you replace them in pairs (which you would anyway) then they look really good.
christine lowery
PostPosted: Tue Jul 15, 2014 8:56 pm    Post subject: Reply with quote
thanks cameron
slight typo l691 but i found them i will put this in information thanks
chris Very Happy
Dalek63
PostPosted: Thu Jul 17, 2014 10:26 pm    Post subject: Reply with quote
Blimey Cameron, you get every where ! lol
Cameron
PostPosted: Mon Nov 24, 2014 10:15 pm    Post subject: Reply with quote
sorry for the very slow reply, but here's the comparison between the original and the new Lucas replacements.
Kind regards,
Cameron
(image link fixed, RJ)
christine lowery
PostPosted: Sun Nov 30, 2014 1:58 pm    Post subject: Reply with quote
these are the fitted lights in the mid seventies
http://www.autoelectricalpartsuk.co.uk/products/Lighting/_Marker_Lights/Durite_Front_Marker_Lamp_with_Cable___016200.html
christine
PostPosted: Sun Nov 30, 2014 11:03 pm    Post subject: Reply with quote
Christine, probably a long shot, but these appear to be similar to the Scintex lenses found on early Peugeots, scroll down to see a pic:
http://nezdecochon.forumparfait.com/restauration-inventaire-vt1546-270.html
http://www.leboncoin.fr/equipement_auto/584697605.htm?ca=12_s
Idea
