Jason
Joined: 12 Nov 2008 Posts: 623 Location: Todmorden, Lancs.
Posted: Sun Aug 03, 2014 9:08 pm Post subject: What is this? |
photo taken today at Hebden bridge of a 'bull nose morris'
is the gear drive on the wheel for the speedo? if not, what is it for?
thanks
jason _________________ "people with money buy a Rolls Royce, people with taste buy an Alvis". |
Joined: 31 Jul 2009 Posts: 1815 Location: Market Warsop, Nottinghamshire
Posted: Sun Aug 03, 2014 9:13 pm Post subject: |
| Yes, indeed, that's the speedo drive. Early cars did not have speedos as standard, so there was no gear drive off the gearbox or rear axle. |
Jason
Posted: Sun Aug 03, 2014 9:24 pm Post subject: |
cheers mike, I thought it was but took the photo as I knew someone on here would know for sure ......I've never seen one before
thanks
Posted: Mon Aug 04, 2014 6:29 am Post subject: |
Are you sure it isn't a very early form of ABS?
When I first saw the above I thought they were an electronic speedo drive, It seems that every time something new comes out it has already been done before though maybe for a different purpose. _________________ Bristols should always come in pairs.
Jason
Posted: Mon Aug 04, 2014 7:15 am Post subject: |
I had a good idea that it wasn't for ABS.  _________________ "people with money buy a Rolls Royce, people with taste buy an Alvis". |
Posted: Mon Aug 04, 2014 7:50 am Post subject: |
| mikeC wrote: | | Early cars did not have speedos as standard, so there was no gear drive off the gearbox or rear axle. |
| Jason wrote: | | I had a good idea that it wasn't for ABS. |
I suppose you could say that learning, at last, what speed you were going enabled you to avoid skidding by warning you of the increased risk levels; thus it does do a similar job even if it isn't autonomous.  _________________ Bristols should always come in pairs.
