Posted: Thu Oct 08, 2015 7:37 am Post subject: Talking of Screwdrivers. |
Prompted by the lively debate about Engine Oil, how about the humble screwdriver.
Paint Can opener.
Lever.
Punch
are just a few of their uses. However I do have a good set that are used only for their intended purpose. (Most of the time)
Posted: Thu Oct 08, 2015 8:08 am Post subject: |
Its not the first time I have had to puncture through an oil filter to get it off because someone had screwed it on too tight _________________ The Clan Chieftain |
Joined: 31 Jul 2009 Posts: 1809 Location: Market Warsop, Nottinghamshire
Posted: Thu Oct 08, 2015 8:51 am Post subject: |
Along with the hammer, the most useful tool in the toolbox  |
Posted: Thu Oct 08, 2015 10:13 am Post subject: |
I find an ordinary screwdriver an invaluable tool for opening those f****** horrible ring pull food cans. Seriously, what on earth was wrong with a can opener? |
BigJohn
Posted: Thu Oct 08, 2015 4:49 pm Post subject: |
Villians ignition key of choice back in the 80's |
Joined: 23 Nov 2007 Posts: 4861 Location: Swindon, Wilts.
Posted: Thu Oct 08, 2015 6:09 pm Post subject: |
BigJohn wrote: | Villians ignition key of choice back in the 80's |
Also used at the top of the door to help get the coat hanger hook past the seals in order to pop the lock button or hook the door handle.
Not needed so often for this after the invention of plastic packaging strip. _________________ Bristols should always come in pairs.
Posted: Thu Oct 08, 2015 6:13 pm Post subject: |
Re the above, I once locked myself out of a Mini, around '66, with the engine still running, I got back in by using something from under the bonnet.
What was it and how did I use it to gain entry? _________________ Bristols should always come in pairs.
Posted: Thu Oct 08, 2015 6:26 pm Post subject: |
Penman wrote: | Hi
What was it and how did I use it to gain entry? |
Spare key ?  |
Penguin45
Posted: Thu Oct 08, 2015 7:11 pm Post subject: |
Dipstick. _________________ '67 Wolseley MkI 18/85, '70 Austin MkII 1800 The Landcrab Forum. |
Posted: Thu Oct 08, 2015 7:34 pm Post subject: |
Penguin45 wrote: | Dipstick. | Who is ? |
Posted: Thu Oct 08, 2015 8:46 pm Post subject: |
The bonnet stay??
Posted: Fri Oct 09, 2015 1:40 pm Post subject: |
Maybe a screwdriver you keep under the bonnet somewhere in case you lock yourself out.  _________________ The Clan Chieftain |
BigJohn
Posted: Fri Oct 09, 2015 1:50 pm Post subject: |
Early Mini? probably your hands, you just reached in and peeled the rusty bulkhead away ...... |
Posted: Fri Oct 09, 2015 2:35 pm Post subject: |
One person has "what" right, but how was it used? _________________ Bristols should always come in pairs.
Posted: Fri Oct 09, 2015 2:56 pm Post subject: |
Penman wrote: | Hi
One person has "what" right, but how was it used? |
Push the dipstick between the two sliding windows, press the little chrome button catch & open the window. (This assumes the catches haven't been reversed). _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
