Posted: Mon Nov 19, 2018 4:03 pm Post subject: Temp sender
Armstrong Siddeley Star Sapphire. Temp sender appears..as are most things on this car...to be unique ,or at least rare to type.
stamped Smiths, marked 3500/0 then another obscured digit which may also be a 0 or a 9 ?
60mm long....15mm across the threads..with a tapered seat.
Near open circuit cold...about 40ohms in boiling water ( does that sound right? )
Any idea who might have stock ? [/img][img]
[/img] _________________ '60 Armstrong Siddeley Star Sapphire
'80 Reliant Scimitar
Posted: Mon Nov 19, 2018 5:23 pm Post subject:
Have you tried ASOC stores? These sort of parts they usually hold.
Alternatively, try Speedograph Richfield in Nottingham.
They do instrument repairs so should be able to tell you the technical info.
