Electric fan thermostat switch
Sid
PostPosted: Mon Aug 24, 2020 11:14 pm    Post subject: Electric fan thermostat switch Reply with quote
My V8 Pilot had an electric fan fitted by a previous owner, but is operated by a toggle switch on the dash. Ideally I would like a thermostat switch to operate it automatically, and possibly retain the manual switch.
Has anyone done this on their classic, and if so can they point me to a decent quality one?
Thanks in advance.
consul 57
PostPosted: Tue Aug 25, 2020 9:28 am    Post subject: Reply with quote
i got one from ebay a complete set with a radiator probe, easy to fit and works fine once you decide on when the fan should come on.
PostPosted: Tue Aug 25, 2020 5:03 pm    Post subject: Reply with quote
just wire the stat and dash switch in parallel, then you can let the stat do its job but override to switch on if necessary.
Dabve
PostPosted: Tue Aug 25, 2020 5:36 pm    Post subject: Reply with quote
Dabve
Isn't he saying he doesn't have a thermostat with his fan - only a manual switch?
The Aeroline electric fan I bought from bbclassiccars came with a thermostat.
https://www.ebay.co.uk/itm/9-80w-Aeroline-Electric-Radiator-12v-Cooling-Fan-With-Thermostat-UNIVERSAL/151054632194?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Sid
PostPosted: Tue Aug 25, 2020 6:15 pm    Post subject: Reply with quote
Yes Ray, I've inherited the fan, but it operates manually only. I was just asking if anyone can recommend a reliable stat operated switch. Most appear to be made in China and look a bit cheap and nasty.
PostPosted: Tue Aug 25, 2020 6:31 pm    Post subject: Reply with quote
https://www.holden.co.uk/c/electrical/heaters_electrical_fans/electric_fans/page/2
They sell the ''Revotec'' fan switches..
These consist of a length of aluminium tube/pipe, which is inserted into the top hose [with clamps.]
They sell various diameters of pipe to suit.
The prices are also aimed at the well-heeled ''classic car owner'', who must have cash to spare?
Also available at various other go-faster specialists..who might be cheaper?
PostPosted: Tue Aug 25, 2020 7:00 pm    Post subject: Reply with quote
That's right, Sid. The one I have is pretty cheap and nasty. Before Covid did for my business I would have probably have gone for one of those that Alastair says are for the well heeled....
I think my "well heeled" days are gone so I shall have to put up with a lot more cheap and nasty stuff before my time is up. Crying or Very sad
Still, I try to put a brave face on it with sayings like "worse things happen at sea!"
Sid
PostPosted: Wed Aug 26, 2020 6:45 am    Post subject: Reply with quote
Well I'm certainly not a well healed classic car owner, or well healed anything come to that. Maybe I'll carry on looking at the bargain basement end of the market, I certainly can't justify over £60 just for a switch.
I'm just not happy buying anything with "Made in China" on it at the moment.
PostPosted: Wed Aug 26, 2020 7:38 am    Post subject: Reply with quote
A good quality (Honeywell) fixed temp stat will set you back around £8, a good variable stat around £20
https://uk.rs-online.com/web/c/automation-control-gear/industrial-switches/thermostatic-switches/
Penguin45
PostPosted: Wed Aug 26, 2020 10:32 am    Post subject: Reply with quote
You should still only use the thermostat to switch a relay to operate the fan.
Chris.
PostPosted: Wed Aug 26, 2020 11:00 am    Post subject: Reply with quote
Interesting, those fixed temp switches. To be mounted against the upper radiator tank I presume.
Sid
PostPosted: Thu Aug 27, 2020 7:17 am    Post subject: Reply with quote
That looks like the best option for me.
PostPosted: Thu Aug 27, 2020 2:46 pm    Post subject: Reply with quote
What you commenly see in the automotive industry is that anything electrical has a huge price hike when its sold as an automotive component e.g. a 50p capacitor is repackaged as a £5 condensor (condensor being the old name for a capacitor that the rest of industry moved from 50+ years ago !) similar with these stats.
PostPosted: Fri Aug 28, 2020 3:01 am    Post subject: Reply with quote
Vaguely relevant is this simple dual temperature gauge & probes:
https://www.ebay.com/itm/Universal-Car-0-28LED-Dual-Digital-Display-Supercharger-Temperature-Gauge-Meter/362459907547
2002 MINI Cooper 'S'
