My new pop project - '53 Sit Up and Beg
Goto page 1, 2, 3, 4  Next
AmusingEmu
PostPosted: Thu May 13, 2021 12:08 pm    Post subject: My new pop project - '53 Sit Up and Beg Reply with quote
Having wanted one for a long time the opportunity presented itself to buy my dream car a 1953 Sit up and Beg Ford Anglia. Body work is in great condition and has matching chassis and engine numbers along with the original paperwork.
The plan is to make this into a daily driver and have already started the process of sourcing parts etc.
Rough Plan below, I initially wanted to keep within the 8 point rule but this seems impossible to maintain while retaining all the comforts that I want for a daily driver so will now be a BIVA build which allows for quite a bit more freedom:
105e Rear Axle
105e front hubs for disc conversion
Engine swap for a mid 90s engine
Internal roll cage
seatbelts
heaters
replace floor pan
reskin roof
[/img]
consul 57
PostPosted: Thu May 13, 2021 4:45 pm    Post subject: Reply with quote
nice
PostPosted: Thu May 13, 2021 5:47 pm    Post subject: Reply with quote
Hi, looks like a good car, is that an old Volvo I spy in the background?
lowdrag
PostPosted: Thu May 13, 2021 8:39 pm    Post subject: Reply with quote
So the vacuum wipers are not staying then? Very Happy Very Happy Very Happy
PostPosted: Thu May 13, 2021 10:29 pm    Post subject: Reply with quote
No reason not to run the vacuum wipers off a modern engine.
Peter Shocked
PostPosted: Thu May 13, 2021 10:43 pm    Post subject: Reply with quote
I wonder how the narrow wheels and cross ply tyres will handle all that extra power in the corners? ... or is that what the roll cage is for? Shocked
PostPosted: Thu May 13, 2021 11:20 pm    Post subject: Reply with quote
Peter Shocked
The roll cage tubing could also serve as a Vacuum Reservoir. Laughing
PostPosted: Fri May 14, 2021 2:27 am    Post subject: Reply with quote
Somebody has to say it:
If it's as largely original as it appears to be, I'd leave it alone.
2002 MINI Cooper 'S'
PostPosted: Fri May 14, 2021 8:43 am    Post subject: Reply with quote
If it were a basket case then I would have no qualms about it but it's not my car so not by business.
Whilst the cost may be prohibitive at the moment, have you considered an Electric conversion?
https://www.autocar.co.uk/car-news/used-cars/how-put-electric-car-your-driveway-little-%C2%A3900
PostPosted: Fri May 14, 2021 11:43 am    Post subject: Reply with quote
It does not have the typical sagging top rear door window. Also the front wheel arch in combination with the wheel does not seem Volvo.
Something American?
Vulgalour
PostPosted: Fri May 14, 2021 9:39 pm    Post subject: Reply with quote
Ford Falcon wagon from about '62 maybe. Has that sort of look about the front fender.
AmusingEmu
PostPosted: Mon May 17, 2021 2:49 pm    Post subject: Reply with quote
they will be banded to allow some extra grip and a better ride overall or at least that is the aim
PostPosted: Mon May 17, 2021 10:48 pm    Post subject: Reply with quote
Sorry ... but what is "banded"?
Minxy
PostPosted: Mon May 17, 2021 11:15 pm    Post subject: Reply with quote
The wheel is cut in half and a ‘band’ of metal welded in to make the wheel wider while still looking stock from the side.
Page 1 of 4
