Miken
Posted: Sun Nov 10, 2024 7:01 pm Post subject: Dynamo Swap |
My A40 has a Lucas C39 dynamo fitted as standard. I have been given a nice unused, reconditioned C40 Item. Is this a straight swap? Does it require a different voltage regulator?
Thanks |
bjacko
Joined: 28 Oct 2013 Posts: 557 Location: Melbourne Australia
Posted: Mon Nov 11, 2024 4:58 am Post subject: Lucas Dynamos C39 and C40 |
Without detailed part numbers such as 22250E/F and model C39PV for example it is impossible to compare. C40's are very rare and do not seem to be fitted to many vehicles. Physically they are 1/2" larger diameter. _________________ 1938 Morris 8 Ser II Coupe Utility (Pickup)
1985 Rover SD1 VDP |
Joined: 23 Nov 2007 Posts: 4309 Location: South Cheshire
Posted: Mon Nov 11, 2024 9:38 am Post subject: |
From a Lucas brochure
Miken
Posted: Mon Nov 11, 2024 10:47 am Post subject: |
| ukdave2002 wrote: | From a Lucas brochure
Thanks for that information Dave,
My vehicle has an RB106 control box fitted so it looks like a straight swap for the C40-L |
Southernscouse
Joined: 30 May 2024 Posts: 27 Location: Havant Hampshire
Posted: Sat Nov 23, 2024 3:41 pm Post subject: Dynamo swap |
| I changed mine to a Dynamotor which is a alternator in a dynamo case I then got a broken rectifier box and used this as a junction box under the bonnet things look original but the alternator puts out 14 volts even at tickover |
