Morris8_2020
Posted: Sun Feb 15, 2026 4:58 pm Post subject: Change Brake Master Cylinder |
Hi all
I am looking to change brake master cylinder on a morris 8 ser 1 has anyone done this before 7/8? bore. |
Joined: 23 Nov 2007 Posts: 4442 Location: South Cheshire
Posted: Sun Feb 15, 2026 5:33 pm Post subject: |
Yep it?s 7/8? seals are available from the Morris Register, you will need a 5/8? BSF tubular box spanner to remove and refit the cylinder.
bjacko
Joined: 28 Oct 2013 Posts: 596 Location: Melbourne Australia
Posted: Mon Feb 16, 2026 7:50 am Post subject: Remove Morris 8 Master Cylinder |
You can also do it with an open ended spanner. Do not loose the thin brass washers at the Tee piece when you remove the special BSF threaded bolt.
The washers are two different sizes too. _________________ 1938 Morris 8 Ser II Coupe Utility (Pickup)
1985 Rover SD1 VDP |
