mgcarma Guest
Posted: Mon Oct 01, 2007 3:05 pm Post subject: Need help finding WIPAC oil filters for my Rover P4 Cyclops. |
Hi there, I bought a few Wipac oil filters, online, from someone who sent them to the wrong country. Sadly, he has no more to send me, so I am looking for some help.
I have a Rover P4 Cyclops that uses the Wipac canister filter. I either need a source for NOS filters, or perhaps someone on this forum has found a way to convert to a conventional spin on oil filter?
Any help much appreciated.
cheers
Kevin |
mgcarma Guest
Posted: Mon Oct 01, 2007 3:39 pm Post subject: Wipac oil filters |
I will take pics today, but for now,
it is a WIPAC E3, the A40's used the E1 type,
it is a screw on oil filter that has a 3/8 x 20 thread that threads in to the block, and the canister is about 5" across and is metal, hammerite type finish with the WIPAC decal on the face of the filter.
I'll get you a pic so you can see, cheers
Kevin |
mgcarma Guest
Posted: Tue Oct 02, 2007 3:01 am Post subject: wipac filters |
thanks for the effort, much appreciated. I'll post pics tomorrow.
cheers
Kevin |
mgcarma Guest
Posted: Tue Oct 02, 2007 2:50 pm Post subject: thanks anyway rick, |
working on pics.
meanwhile, here is an item number of an auction that is similar:
Item number: 150164786647
let me know what you think.
cheers
Kevin |
mgcarma Guest
Posted: Wed Oct 03, 2007 2:53 am Post subject: so, what to do? |
So, what do people do that have these filters?
they are pretty hard to find, is there a conversion kit?
thanks
kevin |
Posted: Wed Oct 03, 2007 7:37 am Post subject: |
There is a kit available to replace the type of filter used on the A40 & Ford Pop, basically an adapter to which a later spin on filter can be fitted. There is one for Ford engines that looks like the old-style canister, but opens up and a modern one is fitted to an adapter inside, thus preserving the look of an old-style filter.
I don't know if there is an equivalent conversion for the smaller Standard 10/Early Minor filter or not, but I bet there is somewhere
mgcarma Guest
Posted: Wed Oct 03, 2007 12:51 pm Post subject: Can you tell me where I can find one of these adapters? |
I will post a question on the list here, but if you can help me find the adapter, I'd sure appreciate it.
The thread that threads into the block is a 3/8 x 20 thread....
I have a car that can't move right now because it has a 40yr old oil filter on it......so any pointing in the right direction to the conversion kit you speak of is much appreciated.
cheers
Kevin |
