eddie
Posted: Tue Jun 10, 2008 7:33 pm Post subject: Mg Midget - twin carbs query |
Hi pals, I have just purchased a 1967 MK 111 midget with twin su carbs what I don't understand is there is no vacuum advance can anyone tell me why. Also can anyone advise how to set the carbs as the engine idles lumpy contact breakers are ok spark plugs are new I am not certain about the timing it is a 1.275 cc I could do with advice on how to set that .
Edd |
Posted: Wed Jun 11, 2008 3:47 pm Post subject: |
Hi Eddie,
I've recently been working on my Sprite and changed the distributors.
As you can see there is a diaphragm on the distributor and it should connect, by pipe, to the left of the left hand(front) carb, close to where it bolts to the manifold.
It will certainly run rough if this pipe is missing. |
eddie
Posted: Wed Jun 11, 2008 4:49 pm Post subject: |
Hi Peter, There is no vacuum unit on the dissi at all !! I.am baffled
Eddie |
Posted: Wed Jun 11, 2008 5:28 pm Post subject: |
Hi Eddie,
Is the body of the distributor designed to take a vacuum unit (like in pigtin's photo) but the unit is simply missing?
In some more modern distributors the body is a pressing rather than a casting and the vacuum unit just screws onto the side and a rod pokes through a hole to rotate the contact plate.
Another, most unlikely possibility is that your car has somehow been fitted with a pre-war distributor that never had any vacuum control. (Not a serious suggestion)
Peter |
Joined: 23 Nov 2007 Posts: 4242 Location: South Cheshire
Posted: Wed Jun 11, 2008 5:40 pm Post subject: |
Hi Eddie and welcome
A vacuum leak in the induction system can often cause a rough idle, which if the hose is missing might account for both problems.
eddie
Posted: Wed Jun 11, 2008 7:57 pm Post subject: dissi |
Hi Peter,
There is nowhere on my dissi . for a vacuum unit to attach.
So where do we go now its beyond me !!
Eddie |
