Roverron
Posted: Sat Aug 30, 2008 6:03 pm Post subject: Mystery objects |
Anybody recognise what these are(or were)? They are from my... Rover _________________ To Hell with ambition, it drives a man mad, I can scarcely wake up to be fed. |
Posted: Sat Aug 30, 2008 6:19 pm Post subject: |
Could you take the photo from a bit further away, so they are in focus, or is it that part of the challenge?
Like those "recognise this from an unfamiliar angle" quizzes.  |
peppiB
Posted: Sat Aug 30, 2008 6:29 pm Post subject: |
| The way they are there, they look like spent air gun pellets!! |
Roverron
Posted: Sat Aug 30, 2008 6:38 pm Post subject: |
If they were less fuzzy it would be too easy  _________________ To Hell with ambition, it drives a man mad, I can scarcely wake up to be fed. |
Posted: Sat Aug 30, 2008 8:05 pm Post subject: |
Which Rover? _________________ Rover P2
62rebel
Posted: Sat Aug 30, 2008 10:38 pm Post subject: |
i'll hazard a guess that you found these in a very bad place; inside the combustion chamber? i'll then hazard that they are the missing washers from your air cleaners; the nuts possibly too heavy to be pulled into the carb throat, but washers light enough?
if not, then i'm scuppered as to what they are. |
Roverron
Posted: Sun Aug 31, 2008 5:22 pm Post subject: |
Here is a better picture for those of you who are still puzzled. The big clue is the line which can be seen on the l/h one The Rover is a '46 ten _________________ To Hell with ambition, it drives a man mad, I can scarcely wake up to be fed. |
Posted: Sun Aug 31, 2008 5:29 pm Post subject: |
The remains of a small end and its bush? _________________ Due to the onset of my mid eighties I'm no longer sprightly and rarely seen in my Austin special. I have written a book though. https://amzn.eu/d/7rwRRqL |
Posted: Sun Aug 31, 2008 6:10 pm Post subject: |
The head of a slotted bolt, or self tapping screw _________________ ROVER
One of Britain's Fine Cars |
Posted: Sun Aug 31, 2008 6:28 pm Post subject: |
Is it valve heads?
Roverron
Posted: Sun Aug 31, 2008 6:50 pm Post subject: |
Well done Art, they are indeed valve heads (both exhaust). The slot on the l/h one is for a screwdriver for grinding in the valve. The head broke off its stem, once in 1987 and another in about 1998, different cylinders. The inlet valves and the pistons hammered the heads into these shapes before I switched off/pulled up. On neither occassion was I going fast, both times about 45-50mph. I found the valve heads in the sump each time. Here is the piston from the first time which happened on the A1 on the way to Cambridge. Guess what I said at the time.
Posted: Sun Aug 31, 2008 7:34 pm Post subject: |
I expect you said something like I just did when I saw your last picture, not to be repeated in public however!
