Oliver
Joined: 13 Jan 2008 Posts: 5 Location: near Lyon, in France
Posted: Fri Feb 06, 2009 8:48 pm Post subject: Wanted 489 lucas lens |
Wanted 489 lucas lens in red for my sidecar, please
Same as this, in red :
Not soo easy to find this here in France.
Thanks for your helps
liver |
Greeney in France
Oliver
Posted: Sat Feb 07, 2009 10:30 pm Post subject: |
Thanks for your helps, Greeney, but I can't find 489 one's.
Actually I have a 489 white lens with some red paint..!  |
Posted: Sat Feb 07, 2009 10:58 pm Post subject: |
If you have white lenses find a craft shop/store where they have glass paints for stained glass work.
I have used an amber, glass, felt tip to put the coating back on an amber bulb for my modern.
Might have to put the colour on the inside of the lens to make it last longer. |
Joined: 16 Oct 2008 Posts: 1174 Location: Upper Swan, Western Australia
Posted: Sun Feb 08, 2009 5:34 am Post subject: |
Oliver,
I bought some dye designed specifically for colouring indicator lenses in a speed shop in Australia. I needed amber and red to colour the rearlamp lenses of my Kombi which the sun had burned clear. It was cheap and extremely good. Five years later there is no sign of the colours fading.
If we can get it in Australia, it must be available in the UK or France! This stuff is called "Speciality Lens Dye" made by Speciality Automotive, Croydon Park, NSW, 2133, Australia.
Keith |
Brian M
Posted: Sun Feb 08, 2009 10:40 am Post subject: |
| Penman wrote: | Hi
Used the stained glass paint in red to convert a Lucas L494 reversing light into a rear fog light. One of these:
I didn't know that Lucas had made a fog light as well, and that they are now very rare, so I was delighted when I was offered four times what I paid for it that came down to three times when I told them mine was not original! _________________ Brian
Posted: Sun Feb 08, 2009 4:40 pm Post subject: |
I wonder if the 489 is the white lens and you are looking for the wrong part number.
I found part number 488 on ebay if this is any use
LUCAS L488 PAIR OF RED GLASS LENS _________________ ROVER
One of Britain's Fine Cars |
Oliver
Posted: Mon Feb 09, 2009 11:14 pm Post subject: |
Thanks for your helps !
For "47p2" : 488 lucas lens are bigger than 489 one's
When I found my sidecar there is a 489 lucas lens on the back but the lens fell on the road at the first ride out !
I just want to keep my watsonian Bambini sidecar as original if possible !!
I just know that white 489 lens are for Aston Martin, Morris Minor, early Land Rover.......!
On what car can I found red 489 lens, please ??
488 lens :
489 lens :
Watsonian + 1958 125 LI Lambretta:
Posted: Mon Feb 09, 2009 11:35 pm Post subject: |
I searched for a red 489 on the net and there was no mention of it in red so I think you will need to paint it until one turns up.
Wolseley also used the white front 489s but not on the rear  _________________ ROVER
peppiB
Oliver
Posted: Thu Feb 12, 2009 1:40 pm Post subject: |
| Rick wrote: | I can't think of any car that has a red 489, the clear ones are used on the front of my A40 Devons, and the Standard 10 I once had, along with '50s Minors etc. I had a look through a box of old lenses and I found some clear ones, but no red sadly
Rick |
I can't think that Watsonian have this lens only made for the MK2 Bambini sidecar.
Is it possible to find Lucas lens list for all car, please ?
Thanks for all yours helps,
Oliver |
