Desperate for a Triumph Herald 1200 engine or Standard 10
Missrhythm
PostPosted: Fri Apr 30, 2010 12:29 pm    Post subject: Desperate for a Triumph Herald 1200 engine or Standard 10 Reply with quote
Sad
I just bought Stanley my Standard 10 and he is broken.... His engine died on the way home.
He has (had its out) a Triumph Herald 1200 (37bhp) engine fitted...
I Soooooooooo need to get him back on the road he is my only car....
Is there someone out there who can help me please.
A short engine would suffice, if it is a Triumph...
I am so fed up and would be so happy if someone could help......
A Huge thanks for any help......
Emma.
Rolling Eyes
PostPosted: Fri Apr 30, 2010 12:54 pm    Post subject: Reply with quote
Sorry to hear about that!!
If you're quick there's a Herald chassis with 1296cc engine, on ebay, finishes at 17.44hr today, currently 99p no reserve. Although slightly larger than the 10 engine (948cc) I can't see why it shouldn't go in, once the engine mounting bracket has been swapped over.
http://www.oldclassiccar.co.uk/ebay.htm?ebaylink=250620682420
PostPosted: Fri Apr 30, 2010 12:55 pm    Post subject: Reply with quote
Also a couple more possibles:
330427852658
330428479686
Rick.
PostPosted: Fri Apr 30, 2010 1:00 pm    Post subject: Reply with quote
Whereabouts are you Emma? It might help if a forum member has a spare engine lying around. Sadly I only have a spare Morris Minor engine Sad
Hope you get it sorted!
Richard Hughes
PostPosted: Fri Apr 30, 2010 1:03 pm    Post subject: Reply with quote
I *may* still have a short motor around the back of the garage, it came with my first "10", however I couldn't vouch for its condition, whether it still turns over or not Confused
Missrhythm
PostPosted: Fri Apr 30, 2010 1:23 pm    Post subject: Wow.... Reply with quote
Blimey........ I am amazed at such a huge response so quickly... I shall look read and reply to all soon thank you...
I have the walk to Tesco to do aaahhhh.... takes up tooo much time....
I am just north of Coventry if that helps.
Speak in a bit and thank you again for all of this help.
Emma
xx
michael1703
PostPosted: Fri Apr 30, 2010 6:00 pm    Post subject: Reply with quote
whats up with your original engine?
may be easier to fix what you have
Missrhythm
PostPosted: Fri Apr 30, 2010 8:17 pm    Post subject: Reply with quote
HI
I will get my mechanic chap to give me the full description and will post it on here.....
But so far £200 before machining and his money..... All money I don't have.....................
Sad Exclamation
PostPosted: Tue May 04, 2010 1:18 pm    Post subject: Reply with quote
A second opinion can sometimes save you a packet! Laughing
Paul
Missrhythm
PostPosted: Tue May 04, 2010 1:22 pm    Post subject: Reply with quote
Yes true...... but think he is right worst luck............
Missrhythm
PostPosted: Tue May 11, 2010 10:55 am    Post subject: Reply with quote
Hi again.
Just got the prices for re bore and crank grinding... Sad
Re bore £80
Crank grind £60
bearings £60
Pistons £240 !!!!!!!!!!!!!!!!!!!!!!!
+vat
HEEEEEELP...............
I am sure pistons can be found a tad cheaper than that???????
Any ideas out there please..
All the best
Emma
Missrhythm
PostPosted: Tue May 11, 2010 1:20 pm    Post subject: My poorly engine... Reply with quote
Hi all again...
Now I can see the crank I was surprised to see the word Standard on it and the con rods....
Is this normal for a triumph herald engine???????
I am a tad confused now..............Shocked
Emma
Shocked
PostPosted: Tue May 11, 2010 2:11 pm    Post subject: Reply with quote
Hi Emma, I don't know much about Triumph engines but it is most likely correct, as "Triumph" was still known as "Standard Triumph" in the early days of Herald production. Early Herald engines are identical to Standard 10 engines (I think)
Is this any good to you?
http://cgi.ebay.co.uk/Triumph-Herald-1200-Engine-/230473371494?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35a9488f66
Richard Hughes
Missrhythm
PostPosted: Tue May 11, 2010 3:06 pm    Post subject: Reply with quote
Oh thank you for that... It could sort me out totally....... Well Stan......
I shall question the owner over a few points and let you know the outcome.
I shall post some photos of Stan soon too.......
He needs a new paint job but that can wait for a bit.
Thanks again fingers crossed...
Emma
x
Very Happy
