Bayliss Thomas
Posted: Mon Oct 04, 2010 2:32 pm Post subject: Winter wheel removal - or not? |
Is it worthwhile jacking up the caravan and removing the road wheels for storage during winter season? |
Onlyrwd
Joined: 04 Oct 2010 Posts: 185 Location: Market Rasen
Posted: Mon Oct 04, 2010 5:29 pm Post subject: |
Yes and no, its just as bad to leave them out all summer unused, UV rays age the rubber and cause cracking.
Both winter and summer will cause flat spots if unused for a long time. Mine are on all year but when its in storage I inflate the tyres to 50psi to help reduce the flat spots.
In answer to your question yes it would be better to remove them during winter, and in summer if you dont use it often. _________________ Mick
78 Cavalier GL
78 Manta Berlinetta
67/68 Thomson Glenelg WANTED |
Bayliss Thomas
Posted: Mon Oct 04, 2010 7:03 pm Post subject: |
Thanks, sounds like time to get the jack out! |
Fluffle-Valve
Posted: Mon Oct 04, 2010 7:54 pm Post subject: |
I've just put my old Castleton away in storage today for the winter. I leave it on its legs, which are wound down so much so the wheels are off the ground. No flat spots on the tyres and takes the weight off of the suspension.
Is this a bad thing to do, leaving it on its legs? I’ve been doing it now for the last four years and haven’t seen or noticed anything to say otherwise. _________________
Onlyrwd
Posted: Mon Oct 04, 2010 8:06 pm Post subject: |
The legs are designed to steady it not lift it, it will put a lot of stress on the chassis especially on an old Caravan. If the body has any weak points this is a good way to find them I would chock it on blocks of wood or axle stands if you want to keep the tyres off the ground. _________________ Mick
78 Cavalier GL
78 Manta Berlinetta
Scarlet Snail
Posted: Tue Oct 05, 2010 6:04 am Post subject: |
I do this with mine:
scooterdaz
Joined: 31 Aug 2010 Posts: 34 Location: East Riding of Yorkshire
Posted: Tue Oct 05, 2010 9:04 am Post subject: winter wheel removal |
Fluffle-Valve
Posted: Tue Oct 05, 2010 9:17 am Post subject: |
Scarlet Snail wrote: | I do this with mine:
What happened? _________________
Fluffle-Valve
Posted: Tue Oct 05, 2010 9:24 am Post subject: |
Onlyrwd wrote: | The legs are designed to steady it not lift it, it will put a lot of stress on the chassis especially on an old Caravan. If the body has any weak points this is a good way to find them I would chock it on blocks of wood or axle stands if you want to keep the tyres off the ground. | Your right.
I ought to do something about it really. It's been sat for 5 or 6 months each year on its legs. I think I'll go over today and have a crawl around under it... _________________
