Uncle Joe Guest
Posted: Thu Oct 12, 2006 9:28 am Post subject: Classic Car Paintwork |
As some of you know, I started to write a restoration book a while ago.
At present, I am researching into the refinishing. Is there anyone that has practical experience of some of the newer products on the market, such as Corrosion Inhibiting Primers or Galvanising Agents?
Also, is there anyone that has tried using one of these new fangled HVLP, or even LVLP sprayguns? |
admin
Posted: Thu Oct 12, 2006 10:12 am Post subject: |
Never used 'em, but the galvanising agents sound interesting - can they only be used on new metal?
Uncle Joe Guest
Posted: Thu Oct 12, 2006 10:32 am Post subject: |
As far as I can understand, the galvanising agents are used as a wipe-on refinish, so therefore it should be possible to use them on old metal. I haven't a clue if I'm right or wrong, but hopefully someone knows!
How about the primers? |
rustyreks Guest
Posted: Mon Nov 27, 2006 8:32 am Post subject: galvanised primer |
Dulux sell a galvanized primer with rust inhibitor paint you can brush it on straight from the can thought could be good if you were welding a panel you could paint this inside panel first.If interested web site is
www.dulux.co.nz
Can be top coated as well following suitable preparation.This sell several types of galvanised primer the above is best for steel old cars etc. |
