Bengt Axel
Posted: Fri Sep 09, 2011 12:47 pm Post subject: |
| I'll ask my dad when I see him at the weekend. His Velo Clubman has now got to the reassembly, rather than dis-assembly stage, so hopefully not long now!. |
Posted: Sat Sep 10, 2011 10:52 pm Post subject: |
Can't answer this directly Rick. But logically, using only half as many amps to drive things, then only half the amp hours specified for the original at 6 volts.
However bearing in mind that you likely have a more powerful headlamp bulb, used more frequently with modern traffic I would settle for the same capacity as original. Especially if you intend to fit flashers for safety (I won't ride a bike these days without them - young drivers think you are waving at them!)
The modern Gel batteries are much more compact then the old lead/acids so space should not be a problem. In fact a 12volt Gel battery will comfortably fit inside a dummy 6volt case to maintain appearance. With other advantages too.
Anyway, a pint is always better than a half, isn't it?
Bengt Axel
Posted: Mon Sep 19, 2011 12:40 pm Post subject: |
My dad was not much help to be honest - his view is simply that as long as it generates more than it uses, then you are OK (given that you haven't got a starter motor to worry about).
It is something he will have to tackle himself soon as he plans to convert his to 12v, simply to enable him to fit indicators.
Mrs Axel has a degree in Electronics, so I will ask her. |
Posted: Mon Sep 19, 2011 11:14 pm Post subject: |
I think I'd just go for the largest (&/or largest amp/hr capacity) that will fit the case. This will give you the most reserve if the dynamo croaks. A deep-cycle design wouldn't hurt, but they get expensive.
Make sure the terminals are in the right places! _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
