Got a problem..I need to remove glue from a painted surface
websnail
PostPosted: Tue Mar 19, 2013 11:18 pm    Post subject: Got a problem..I need to remove glue from a painted surface Reply with quote
Got a problem...............I need to remove glue from a painted surface.
The paint is faded enamel forty years old on metal.
The glue is an evo stick type.
The surface is around 5 x 7 feet and is on the underneath of a roof!
All ideas welcome.
Thanks in advance.
David
PostPosted: Tue Mar 19, 2013 11:42 pm    Post subject: Reply with quote
if it's contact adhesive, I have removed it with carburettor cleaner, but carburettor cleaner will in quantity remove solvent paints like cellulose, so care is required.
Cheers Dave
Greg
PostPosted: Wed Mar 20, 2013 12:06 am    Post subject: Reply with quote
Or perhaps try a caramel wheel?
PostPosted: Wed Mar 20, 2013 2:15 pm    Post subject: Reply with quote
If it is Evo-stik it is not particularly good in wet conditions so something like a steam wall paper stripper might well encourage it to come off. I assume it is on the underside of the roof!
Paul
ajlelectronics
PostPosted: Wed Mar 20, 2013 10:18 pm    Post subject: Reply with quote
If it really is enamel, try thinners. If it is cellulose don't even think about it. Apart from that, I have found fingertips work quite well, if a little tedious. It's how I do some of my re-upholstery on fibreglass or metal bases.
Evans Waterless Coolants
websnail
PostPosted: Wed Mar 20, 2013 10:56 pm    Post subject: Reply with quote
Paul
Correct. Smile
I was thinking of fingertips and just rubbing it.
Solvent in a enclosed space and above my head, my head is spinning just thinking about it Confused Smile
Desert Fox
PostPosted: Fri May 24, 2013 9:31 am    Post subject: Reply with quote
Lighter fuel. This is what the dent guys use to remove the dollys attached to the bodywork by hot glue melt. Should be good for adhesive.
D4B
PostPosted: Fri May 24, 2013 12:42 pm    Post subject: Reply with quote
I imagine that a caramel wheel used carefully would do the same
job as fingertips but less pain after... goggles required I think Idea
