Bugly
Joined: 25 Jan 2009 Posts: 65 Location: Darwin, Australia
Posted: Sun Jun 23, 2013 1:50 am Post subject: Shock Absorber Fluid |
What do forum members use as 'shock absorber fluid'? Many moons ago this was available as an over-the-counter maintenance product, but no more. I have read that hydraulic jack oil is an acceptable substitute and not too pricy, but would be interested in comments from others as to what thay found works for them.  |
D4B
Bugly
Posted: Sun Jun 23, 2013 11:43 am Post subject: |
Thanks for the feedback gents ... I'll follow up on the Penrite Shocker No.1 fluid, looks just what I need!  |
kismet
Posted: Thu Aug 01, 2013 1:34 pm Post subject: |
| Most motor bike shops have shock absorber fluid on the shelf in a range of grades allowing for some small adjustments of damper rates. |
alanb
Posted: Sat Sep 21, 2013 3:53 pm Post subject: |
I. Have just cleaned and freed off the pear shaped shocks on the rear of my Morris 8 2 seater, having drained the old oil and flushed them with paraffin I then filled them with Citroen LHM hydronic fluid. They now work great. _________________ old tourer
Morris 8 two seater |
BigJohn
Posted: Sat Sep 21, 2013 6:18 pm Post subject: |
When I had my roly-poly Vanguard Phase 2, I met a retired mechanic who served his time on Standards in a rural garage, where a lot of customers towed cattle trailers. I asked him what he did about shock absorbers which were getting soft.
1, EP90, then,
2, EP120, then
3, Fit a grease nipple to the buggers,
was the reply. |
Bugly
Posted: Sat Sep 21, 2013 11:57 pm Post subject: |
| BigJohn wrote: | When I had my roly-poly Vanguard Phase 2, I met a retired mechanic who served his time on Standards in a rural garage, where a lot of customers towed cattle trailers. I asked him what he did about shock absorbers which were getting soft.
1, EP90, then,
2, EP120, then
was the reply. |
That's tailoring the solution to the problem!!  |
