Shock Absorber Fluid
Bugly
PostPosted: Sun Jun 23, 2013 1:50 am    Post subject: Shock Absorber Fluid Reply with quote
What do forum members use as 'shock absorber fluid'? Many moons ago this was available as an over-the-counter maintenance product, but no more. I have read that hydraulic jack oil is an acceptable substitute and not too pricy, but would be interested in comments from others as to what thay found works for them. Confused
PostPosted: Sun Jun 23, 2013 6:43 am    Post subject: Reply with quote
Companies like Penrite list shock absorber/damper oils, I had a bottle or two come with the utes I bought from Oz years ago iirc.
D4B
PostPosted: Sun Jun 23, 2013 11:07 am    Post subject: Reply with quote
Here it is:
http://www.ebay.co.uk/sch/Oils-Lubricants-Fluids-/174123/i.html?_from=R40&_nkw=shock+absorber+oil
Bugly
PostPosted: Sun Jun 23, 2013 11:43 am    Post subject: Reply with quote
Thanks for the feedback gents ... I'll follow up on the Penrite Shocker No.1 fluid, looks just what I need! Wink Wink
kismet
PostPosted: Thu Aug 01, 2013 1:34 pm    Post subject: Reply with quote
Most motor bike shops have shock absorber fluid on the shelf in a range of grades allowing for some small adjustments of damper rates.
alanb
PostPosted: Sat Sep 21, 2013 3:53 pm    Post subject: Reply with quote
I. Have just cleaned and freed off the pear shaped shocks on the rear of my Morris 8 2 seater, having drained the old oil and flushed them with paraffin I then filled them with Citroen LHM hydronic fluid. They now work great.
old tourer
Morris 8 two seater
BigJohn
PostPosted: Sat Sep 21, 2013 6:18 pm    Post subject: Reply with quote
When I had my roly-poly Vanguard Phase 2, I met a retired mechanic who served his time on Standards in a rural garage, where a lot of customers towed cattle trailers. I asked him what he did about shock absorbers which were getting soft.
1, EP90, then,
2, EP120, then
3, Fit a grease nipple to the buggers,
was the reply.
Bugly
PostPosted: Sat Sep 21, 2013 11:57 pm    Post subject: Reply with quote
1, EP90, then,
2, EP120, then
was the reply.
Laughing Laughing That's tailoring the solution to the problem!! Wink
