Posted: Thu Oct 10, 2013 12:38 pm Post subject: |
Interesting that it's fitted with a Tachograph. Clearly useful for limiting driver fatigue on long journeys!
Posted: Thu Oct 10, 2013 12:47 pm Post subject: |
How on earth do you mislay the batteries?  |
Posted: Thu Oct 10, 2013 6:51 pm Post subject: |
I don't think Enfield Automotive is connected to Royal Enfield.
http://en.wikipedia.org/wiki/Enfield_Automotive
There is one at MOSI Manchester.
Churchill Johnson
Posted: Thu Oct 10, 2013 9:28 pm Post subject: |
| Ref batteries they would have been worth more than the car,this will sound the death knell for a lot of older electric car's unless the replacement price come's way down. |
Posted: Thu Oct 10, 2013 9:43 pm Post subject: |
| Quote: | Early versions were fitted with 8 x 12-volt traction batteries and a single 12-volt accessory battery. The traction batteries were set up in parallel pairs, with the pairs connected in series to provide 48 volts. Problems with unequal charging and discharging of the parallel pairs resulted in the use of 8 x 6-volt batteries wired as a single series string (still producing 48 volts) being used in later versions of the car.
Six lead acid batteries rated at 165 Ah are used ( 3 in the front and 3 in the back). |
These two statements are actually from the same text. I guess the batteries are 165Ah each!
http://www.iandmelectric.com/products/duracell-golf-car-battery-6-volt
6 x $170 = $1020 (~£640)
