Crooked_Caravan
Posted: Fri Oct 18, 2013 9:29 pm Post subject: Insulation recommendations please! |
Hello everyone!
I'm starting to research materials to insulate my caravan with – now, my boyfriend seems to think we are going to take the caravan to the Alps for a skiing holiday, so wants something of Arctic-spec. I'm a little more realistic~~~ (and I really REALLY like catered chalets) so whilst I want the caravan to be cosy and useable for a good portion of the year, I'm not planning to be mounting any expeditions to the polar regions in it!
What do you suggest?
Thanks! |
Posted: Fri Oct 18, 2013 10:58 pm Post subject: |
Although I don't have a caravan, if I did I would use a urethane, foil backed sheet such as Kingspan. The thinnest you will find is 25mm and in house construction this would be about 100mm short of the regulation amount. In a caravan, with tight joins filled with fireproof expanding foam and foil taped I imagine this would make quite a difference.
Obviously I know that caravan people will have a standard approach to insulation so you can expect some contradiction here.
Have fun. |
christine lowery
Posted: Sat Oct 19, 2013 10:12 am Post subject: |
hi
it depends on how much work you want to do to a caravan top off the range older vans have heavy foil insulation and modern vans expanded foam
the older vans are much better at retaining heat but if you have glass windows you will need heavy curtains with a thermal linning, and we are looking at the covers that motorhomes use on there glass windscreens
i think i could make them out of radiator foil
chris |
Crooked_Caravan
Posted: Sat Oct 19, 2013 3:49 pm Post subject: |
Thanks – this is all really helpful information  |
david_rachel
Joined: 26 Nov 2012 Posts: 144 Location: High Wycombe, UK
Posted: Mon Oct 21, 2013 2:06 pm Post subject: |
I have posted this picture before; it's our caravan in the Alps in May earlier this year - it was our second time touring the Alps with a caravan and in the main we've stayed on designated sites (....out in the wilds only a couple of times).....the advantage with sites, anywhere in the world, is that you can plug in an oil filled, thermostatically controlled, electric radiator. Whilst there is an on-board thermostatically controlled gas heater in the Carlight I wouldn't want to leave it lit whilst asleep or away from the van.
 _________________ David Rachel
1978 Carlight Casetta
1995 Lada Riva 1.5 Est Red |
Fluffle-Valve
Posted: Tue Nov 19, 2013 9:49 pm Post subject: |
That'sa great photo... Great view... _________________
Dalek63
Posted: Tue Nov 19, 2013 11:01 pm Post subject: |
I hope your Carlight has a good hand brake  _________________ I can resist anything except temptation ! ( Oscar Wilde)
OchAye
Posted: Thu Jan 09, 2014 3:00 pm Post subject: |
| Love the PI estate. |
david_rachel
Posted: Sat Jan 11, 2014 8:27 pm Post subject: |
Thanks! It was bought purely as a towcar for the Carlight!
