Glass & reflector separation
JC T ONE
PostPosted: Sun Nov 10, 2013 2:33 am    Post subject: Glass & reflector separation Reply with quote
Hi all,
I need some advice on how to separate glass from reflector, on a headlight / spotlight.
Its glued together with some White (hard) glue, just like on a Cibie headlamp.
And as the Cibie,s one of them has come apart due to age, but the other one wont move.
Jens Christian
http://www.showcars.dk/
PostPosted: Sun Nov 10, 2013 10:06 am    Post subject: Reply with quote
i have had good results by putting the units in the oven on a low temp for about an hour. softens the adhesive if you get the temp right, cracks the glass if you get it too hot however.
kev
JC T ONE
PostPosted: Sun Nov 10, 2013 2:34 pm    Post subject: Reply with quote
kev
Hi,
Kev,
thanks for your reply, but I am afraid of doing just that .
These spots are extremely rare, I have tried to Google them several times,
after I got computer (both in Germany where they were made)
and in English = nothing to be found on the internet ANYWHERE Rolling Eyes
I only found this set (after 25 year search) so I am afraid to brake the glass.
The spotlights are called Condor, incase anyone wonder, or have heard of them.
Jens Christian
PS here is a thread I made years ago =
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=6791&highlight=
Not the easiest lights to find.
JonV2
PostPosted: Fri Dec 06, 2013 12:47 pm    Post subject: Reply with quote
Maybe the glue would soften with acetone or even brake fluid - this wont damage the glass and should be a gentle way to separate the parts...
Jon
1950 MkV Jaguar Saloon (On the Road)
1968 MGB
1959 XK150
JC T ONE
PostPosted: Sat Dec 07, 2013 4:13 am    Post subject: Reply with quote
Hi Jon,
thanks, I will try with those 2 first, and let you know if any of them did the trick?
J C
PostPosted: Sat Dec 07, 2013 1:17 pm    Post subject: Reply with quote
Another thing that might be worth trying so long as everything else is glass or metal, I wouldn't risk it on plastics. A long time ago I found that Nitromors type paint stripper can also soften old glues to the point they can be scraped away - forget how or on what, but I was quite pleased with the result.
JC T ONE
PostPosted: Sat Dec 07, 2013 6:11 pm    Post subject: Reply with quote
Thanks, nice to have a few options to try out, and yes - no worries, these are old spotlights, so metal reflector & proper glass lense.
