Ignition suppression - 1947 Ford Prefect
PostPosted: Tue Aug 07, 2007 7:43 am    Post subject: Ignition suppression - 1947 Ford Prefect Reply with quote
This came through today, can anyone advise?? I'm guessing its still on 6v
1947 Prefect.
We have just bought the above model,it in super condition ,the only thing is
the electrics arent suppressed,what do we do to do this as the neighbors go
mad when we drive in! Sorry to sound a bit naive but we are very new to it.
Thief
PostPosted: Tue Aug 07, 2007 4:06 pm    Post subject: Reply with quote
Back in the 70's you used to be able to buy suppressors to fit to your ignition coil and dynamo/alternator. Also resistor spark plugs and caps were/are available.
Not being familier with a '47 Prefect igntion system I couldn't be sure if any of those items above would fit but it may be a start.
Also, check for any dodgy earth leads.
If it is only 6v then Ht Leads and plug caps maybe the only route or maybe a good auto electrician. Confused
Uncle Joe
PostPosted: Tue Aug 07, 2007 5:58 pm    Post subject: Reply with quote
The chances are, that it is the neighbours TV's that are being affected. Its doubtful therefore that any interference is coming from any other source than the HT leads.
That being the case, the way to go is probably suppressed plug caps AS WELL AS HT leads.
For those that are not aware, it has been an offence in the UK for many, many years to drive about with a car that has unsupressed electrics....
UJ
Jim Reaper
PostPosted: Sat Aug 25, 2007 9:27 am    Post subject: Reply with quote
I would also go for coil and HT lead suppression as a “cheapish” beginning to a rewarding problem to solve - http://www.vehicle-wiring-products.eu/VWP-onlinestore/htterminals/htterminals.php
http://www.autoelectricsupplies.co.uk/product_list/21
UKdave2002
PostPosted: Thu Aug 30, 2007 7:38 pm    Post subject: Reply with quote
I'd tell your neigbours to get SKY Wink No seriously though, just put some suppression on the LT side of the coil, a 1 microfarad capacitor (which you will get for about 20p at any Maplin store) will suppress the LT side (put it betwen SW of the coil and earth), any new supplied HT leads will sort the HT side out, the company which Jim R reffer's to are really good, talk to them about your HT leads.
