Fluffle-Valve
Posted: Thu May 29, 2014 10:37 pm Post subject: Castleton Wheels. |
I have a 1986 Castleton Roberta and it's fitted with 13" wheels and 165/80 tyres. It rides/sits quite low and I was thinking of fitting 14" wheels and tyres to give it a bit of a lift. I've had to make a purpose built towing hitch low on my Series III Land Rover, just so the combination looks level when hitched up together.
Does anyone know what 14" wheels will fit the same PCD as the Castleton. _________________
sheffieldcortinacentre
Posted: Sun Jun 01, 2014 11:19 pm Post subject: |
whats the pcd? |
Fluffle-Valve
Posted: Sun Jul 12, 2015 9:41 pm Post subject: |
PCD is 5.5 inches .
Still looking for some 14" rims and tyres. _________________
Posted: Sun Jul 12, 2015 10:15 pm Post subject: |
if its 4 stud then try 70's beetle.
5 stud porsche or merc sprinter. |
Fluffle-Valve
Posted: Sun Jul 12, 2015 10:57 pm Post subject: |
sheffieldcortinacentre wrote: | if its 4 stud then try 70's beetle.
4 stud.
I'll check out the beatle. _________________
DELETED Guest
Posted: Mon Jul 13, 2015 8:02 pm Post subject: |
DELETED |
Fluffle-Valve
Posted: Mon Jul 13, 2015 10:33 pm Post subject: |
wilson294 wrote: | Why not ft 175 r 13 tyres?
There's a far difference
don't forget to buy commercial tyres |
I've since found out, this is part of the problem. It's running on ordinary car tyres and they always look soft, even at 35psi. I have found some 155x13c LT tyres with a max pressure of 51psi. I'm sure these would bring it up an inch or two. However, like you say, 175's should be better? _________________
DELETED Guest
Posted: Tue Jul 14, 2015 8:48 am Post subject: |
DELETED |
Fluffle-Valve
Posted: Tue Jul 14, 2015 9:59 am Post subject: |
wilson294 wrote: | 155/ wll be too small
you should get 175s for around £55 each fitted
just be aware when changing tyre profile or wheel size you need enough room n the wheel arch for the suspension travel |
I need to have a proper measure up I think? _________________
david_rachel
Joined: 26 Nov 2012 Posts: 144 Location: High Wycombe, UK
Posted: Tue Jul 14, 2015 12:55 pm Post subject: |
35psi is very low. I run my Carlight at 55psi, albeit with 14" radials _________________ David Rachel
1978 Carlight Casetta
1995 Lada Riva 1.5 Est Red |
Fluffle-Valve
Posted: Tue Jul 14, 2015 9:51 pm Post subject: |
david_rachel wrote: | 35psi is very low. I run my Carlight at 55psi, albeit with 14" radials |
I've had a look at the 165/80x13 tyres that are fitted. I thought that the max pressure should have been 35psi, but it states on the tyre 44psi. I have upped the pressure to 40psi and they look a tad better.
However, I think the ultimate goal is to fit 175RX13C LT Tyres. They will fit under the arch with room to spare and they won't look so spongy on the tarmac.
Wilson294, any idea where these £55 a tyre place is?
Any ideas anyone where to get a good brand at a reasonable cost? _________________
david_rachel
Posted: Wed Jul 15, 2015 8:40 am Post subject: |
Choose your tyre and then have a look here:
http://www.camskill.co.uk/
They're one of the cheapest on the internet and delivery is trouble free _________________ David Rachel
DELETED Guest
Posted: Wed Jul 15, 2015 7:15 pm Post subject: |
DELETED |
