Starter spinning but not engaging on Morris 8, intermittent
zagatoman
PostPosted: Sat Sep 26, 2015 5:20 pm    Post subject: Starter spinning but not engaging on Morris 8, intermittent Reply with quote
Hi all,
I went to start the Morris 8 today but initially only got the starter motor spinning but not engaging, after a few more pulls of the starter over a few minutes I eventually got the starter spinning and engaging and started the engine. After a while I stopped the engine and attempted to start the car again but again only had the motor spinning and not engaging. This fault seems to be intermittent, I have looked at all the cable connections, they all seem to be tight. I am recharging the battery tonight as I though if might be a lack of power to get it spinning fast enough, will give another go tomorrow but could it be anything else?
What could cause this intermittent problem?.
Thanks, Paul
Enthusiastic amateur classic car nut.
PostPosted: Sat Sep 26, 2015 6:43 pm    Post subject: Reply with quote
It could be lack of grunt from the battery, or a dodgy connection somewhere, but I'd also look at the main shaft in the starter to see if it's clogged up with dirt/old oil etc.
I had a play with the Commer a few days ago, and the starter's just spinning away on that too and not engaging.
goneps
PostPosted: Sun Sep 27, 2015 3:30 am    Post subject: Reply with quote
Paul,
Already answered on the MR forum. For the benefit of anyone else who may be interested, it's most likely that the Bendix is gummed up with oil that's leaked from the rear of the crankshaft. Easily cured (temporarily) by a squirt of petrol.
Richard
zagatoman
PostPosted: Mon Sep 28, 2015 3:02 pm    Post subject: Reply with quote
Thanks everyone for all your invaluable help. With all the knowledge from you all I now have a fully working starter. I took out the starter and gave the parts a good clean and put a bit of graphite powder on, this in conjunction with a fully charged battery has sorted out the problem.
Unfortunately now another problem have raised their ugly head. I will be starting a new thread to explain my predicament.
Cheers, Paul
