Overhauling Bishop Cam Steering
Rosco663
PostPosted: Thu Dec 17, 2015 2:18 am    Post subject: Overhauling Bishop Cam Steering Reply with quote
Gidday,
Ralph was asking about how to adjust the steering on his Morris 8 inside another thread. I sent this via PM to him but thought it only fair to share with one and all Cool
Rosco
PostPosted: Mon Dec 21, 2015 1:59 pm    Post subject: Reply with quote
Thanks Rosco663! My Jowett is fitted with a Bishop Cam Box the column of which threads itself neatly between the inlet manifold and the cylinder on the off side which adds an interesting dimension to engine overhaul. I agree that most of the wear occurs on the peg, and I am surprised that they do not mention the trick, that I have used on several boxes, of simply pressing the peg out of the arm, rotating it 90 degrees and pressing back (the peg wears on 2 opposite faces only). This often returns a worn box to almost new condition with no capital outlay!
Paul
goneps
PostPosted: Mon Dec 21, 2015 10:06 pm    Post subject: Reply with quote
Always presuming that a previous owner has not already made use of that trick, of course!
Richard
welder
PostPosted: Wed Jan 06, 2016 11:09 pm    Post subject: Reply with quote
Richard
I can't help thinking that anyone with sufficient mechanical knowledge and enthusiasm to strip and repair a steering box would have sufficient nous to get a new one made up and press it into place, should this be the case.
Ian
PostPosted: Thu Jan 07, 2016 8:46 am    Post subject: Reply with quote
New pegs are available and only about £10, so shouldnt break the bank if required.
goneps
PostPosted: Thu Jan 07, 2016 9:44 pm    Post subject: Reply with quote
welder wrote:
Richard
Ian
Yes, but possibly not enough nous to realise that it would need to be case hardened. Therefore Dave's suggestion of a new replacement from a reputable source for a modest sum makes a lot more sense.
Richard
PostPosted: Fri Jan 08, 2016 2:08 pm    Post subject: Reply with quote
Anyone like to divulge a source?
goneps
PostPosted: Fri Jan 08, 2016 2:17 pm    Post subject: Reply with quote
Possibly Ian Harris ian@harris84.fsnet.co.uk, but certainly the various MG parts specialists who supply for the TA, TB and TC.
Richard
PostPosted: Fri Jan 08, 2016 2:31 pm    Post subject: Reply with quote
Here:
http://www.moss-europe.co.uk/shop-by-model/mg/t-type/steering-suspension/steering/steering-ta-tb-tc.html
click on "full listing" otherwise it only displays steering wheel covers!
