7.8mm spade connectors
Paul fairall
PostPosted: Sun Mar 12, 2017 4:41 pm    Post subject: 7.8mm spade connectors Reply with quote
Been looking for just two 7.8mm spade connectors for an electronic power steering column without success. Did see 100 for sale but that's just stupid. They need to take 6mm cable. Any ideas?
1957 ford popular
PostPosted: Sun Mar 12, 2017 6:11 pm    Post subject: Reply with quote
Try Electrical Wholesalers, who may advertise Ampliversal or Thomas & Betts.
Back in the 80, 90, we ran an Electrical Wholesale business and sold thousands of Ampliversal items. Bought them in boxes of 5000 and sold whatever quantity anyone wanted.
Unless you have a proper crimping tool, (the prof' tools crimp the cable and the insulation at the same time) maybe look at soldering it on. Slide off the insulation part and solder it with the terminal in a vertical position with the cable below. Tin the cable first. For 6mm sq cable the terminal size would be identified by the yellow sleeve. (Simple ID. Red Small - Blue Medium Yellow large)
Some stockist may even have the ones deigned for soldering.
We even sold nylon sleeves to slide over the terminal.
PostPosted: Sun Mar 12, 2017 8:20 pm    Post subject: Reply with quote
This page has female "8mm" spade connectors at 24p each, though there's probably VAT and P&P on that, though you'll pay P&P on most things if you can't find a local supplier.
http://www.autoelectricsupplies.co.uk/product/825/category/2
ETA - no use, says "1 - 2.5mm" cable.
Paul fairall
PostPosted: Tue Mar 14, 2017 10:04 pm    Post subject: Reply with quote
Thanks mike, I decided to visit a breakers yard for the first time in 30 years and got the blue plug I needed from a corsa eps ecu. The crimps were going to be for testing it. Someone on another forum offered me one for £6 after I'd stood on my head in the footwell of an old corsa with broken glass and soil, it cost £5.
1957 ford popular
Kleftiwallah
PostPosted: Wed Mar 15, 2017 10:41 am    Post subject: Reply with quote
On things electrical connectors, I'm after the old 'bullet' connectors, used on motorcycles rather than cars. I only need a dozen. Any ideas out there?
Cheers, Tony. Smile
alanb
PostPosted: Wed Mar 15, 2017 11:22 am    Post subject: Reply with quote
Try Paul Beck Vintage supplies, he has most things electrical.
old tourer
Morris 8 two seater
PostPosted: Wed Mar 15, 2017 11:28 am    Post subject: Reply with quote
Often the best way - though if someone wanted £6 for one it sounds like a weird connector. After writing above I thought that a 7.8mm spade connector for a 6mm cable was quite strange, too, unless your 6mm includes insulation where I think the spec I mentioned does not.
Paul fairall
PostPosted: Thu Mar 16, 2017 10:51 pm    Post subject: Reply with quote
i think someone else mentioned 6mm cable whereas the cable fitted to the plug looks like 4mm multi strand. The 7.8mm is the width of the spade.
1957 ford popular
Paul fairall
PostPosted: Thu Mar 16, 2017 10:56 pm    Post subject: Reply with quote
Cheers, Tony. Smile
vehicle wiring products
1957 ford popular
jp928
PostPosted: Wed Mar 29, 2017 6:27 am    Post subject: Reply with quote
http://www.ebay.com.au/itm/Waterproof-Motorcycle-Bullet-Connectors-3-9mm-Male-Female-BRASS-10-OF-EACH-/152481466359?hash=item23809a87f7:m:mWiZwkNcBnFYC_I-Fif_JMQ
jp 26 Rover 9
