Mystery car found in California
farmerjohn49
PostPosted: Mon Apr 17, 2017 6:02 pm    Post subject: Mystery car found in California Reply with quote
Hello all,
New member, hopefully I am posting in the correct pace!
Found, bought and brought home just this alloy body with steel wings (wings similar to MG TC) has bench seat, folding top, looks RHD. No bonnet, radiator, chassis, engine or gearbox.
Have no idea what it is, any ideas?
Thanks, John B
http://s1320.photobucket.com/user/farmerjohn49/library/
PostPosted: Mon Apr 17, 2017 6:35 pm    Post subject: Reply with quote
Hi John,
Welcome to the forum.
I don't think it's an MG of any description. The fuel tank and front valance and the steel structure suggest that it might be a replica. Possibly a Wolseley Hornet replica??
PostPosted: Mon Apr 17, 2017 10:51 pm    Post subject: Reply with quote
I don't think it is a Wolseley. I had a '33 MG Magnette (same car) for a short while and although the four seater body looks similar it's the bonnet louvres for me that makes it a non Nuffield product. The brake drums AIRC filled the wheel rims too so I assume the Wolseley would have too. What about a Squire?
Art
PostPosted: Mon Apr 17, 2017 10:52 pm    Post subject: Reply with quote
Art
PostPosted: Tue Apr 18, 2017 3:30 am    Post subject: Reply with quote
Kit car?
RHD
NZ?
2002 MINI Cooper 'S'
PostPosted: Tue Apr 18, 2017 9:25 am    Post subject: Reply with quote
Art
Sorry Art, The photo you are referring to is one I used as an example of a car that I thought John's shell might be a "replica" of. I admit it's not a very close replica. It's probably not intended to replicate any particular car but just to look like a 1930s two seater in general.
PostPosted: Tue Apr 18, 2017 10:59 am    Post subject: Reply with quote
Peter,
Confused of Bothwell made that reply. I missed the link in the OP and was using 'your' picture as reference.
Art
PostPosted: Tue Apr 18, 2017 9:48 pm    Post subject: Reply with quote
But what is that panel (5th pic) with the louvres and the domed type piece in the centre?
Could it be an apron from between the front mudguards and in front of the Rad, perhaps covering a blower.
PostPosted: Tue Apr 18, 2017 10:19 pm    Post subject: Reply with quote
I wonder if:
The front wings were put on the opposite sides
& then see if the louvered piece lines up somehow.
The 'fuel tank' at the back looks a bit big to me, although it seems to have a filler cap, it also has a big bolt on the side - is it a cover for a VW engine, perhaps?
PostPosted: Tue Apr 18, 2017 10:25 pm    Post subject: Reply with quote
Would the details on that rear reg. plate maybe give a few clues?
PostPosted: Tue Apr 18, 2017 10:50 pm    Post subject: Reply with quote
It might be this one:
http://www.ebay.com/itm/1970-Replica-Kit-Makes-vw-beetle-/162469341499?rmvSB=true&utm_medium=referral&utm_source=car.mitula.us&nma=true&si=kOtrsjHzEq1tw429Wo7mxZ39keA%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
PostPosted: Wed Apr 19, 2017 12:19 am    Post subject: Reply with quote
It's a very stylised apron and doesn't look as if it ever contained a blower. I think it's just a "look alike" blower cover. (Where does the carb and air intake fit?)
farmerjohn49
PostPosted: Thu Apr 20, 2017 2:42 am    Post subject: Reply with quote
Not a VW knock-off for sure, the apron or filler panel with louvres is definitely the connector panel between the wings in front of the rad. Has a starter handle hole.... no room for blower.
Not sure why so many instruments on passenger side, and left side is the passenger side as grab handle there too.
If I find more clues on the shell I will let you know!
Thanks for the suggestions,
John B
PostPosted: Thu Apr 20, 2017 9:13 am    Post subject: Reply with quote
Probably for better instrument visibility?
Plus, better access for instrument maintenance?
Is that part of a torque tube sitting on top?
Riley9
PostPosted: Thu Apr 20, 2017 10:17 am    Post subject: Reply with quote
peter scott wrote:
Hi John,
This looks like a genuine Wolseley Hornet to me. The radiator does not look like MG.
