Screen Frame
PostPosted: Sat Dec 29, 2007 3:49 pm    Post subject: Screen Frame Reply with quote
I have finished welding my screen frame, now just need to make, drill and tap the angled joining pieces for the bottom, may weld some or cut some from some plate.
I have one spare, that I will make useable at least.
Some pics later hopefully!
PostPosted: Mon Dec 31, 2007 10:02 pm    Post subject: Reply with quote
Pics:-
Still needs painting properly, just painted it quickly to stop the rust setting in on the welds and ground bits, then thought I may as well paint the lot!
hehe
Needs painting again though, and before fitting, will put either some vaseline or red rubber grease in, under the rubber seal, and a bit around the rubber seal by the glass, so should combat any water!
Solid now at least!
Dave Very Happy
P.S... I have one of the hinge fixings thats holds the bonnet on, but need one to go on the grille if anyone has one?
PostPosted: Sat Jan 05, 2008 11:49 pm    Post subject: Reply with quote
the screen surround came up looking good! I don't think I have any of the bonnet mounting brackets unfortunately.
PostPosted: Sun Jan 06, 2008 9:39 am    Post subject: Reply with quote
Yeah I am pleased with it, I could have got it perfect, smoothe and shiny, but it is not really what I wanted. To do this I would have had to apply some polly, and I think it is better being metal, showing a little pitting, to show it is old etc.
I think I may make a small ford spares order up, so will try to get a bonnet thingy there.
ES2
PostPosted: Tue Jan 08, 2008 8:37 pm    Post subject: Reply with quote
Hi looks great - what plans for the spare you mentioned ES2
PostPosted: Tue Jan 08, 2008 8:52 pm    Post subject: Reply with quote
The spare has rot at the bottoms, I sand blasted it, so can see what needs doing to it. Ideally I will get another rotten one to let new pieces in. They do rot quite alot, so may have one as a spare not sure. Do you need one?
ES2
PostPosted: Wed Jan 09, 2008 9:55 am    Post subject: Reply with quote
Hi Yup - just have a hole at the moment. ES2
ka
PostPosted: Wed Jan 23, 2008 9:12 am    Post subject: Windscreen Reply with quote
Did you do the bends, or cut and weld?
I need a new screen surround, and I have been looking for a way to get the curves.
Kim
PostPosted: Wed Jan 23, 2008 6:39 pm    Post subject: Reply with quote
Luckily the curves were ok on my frame, just the lower sections that need repairing.
rustyreks
PostPosted: Sun Nov 16, 2008 9:48 am    Post subject: windscreen Reply with quote
They normally rot at the bottom corners on mine when the seal deteriorated the water went in at the top of the frame via acouple of holes on the frame and the water sat inside the frame at he bottom the other thing that is a problem is the drain holes in the cab get blocked so the water sits in the frame channel at each end of the screen and the screen rots from the outside why they didnt make them in brass is beyond me i have a reasonable screen but the glass is shot the problem will be pulling it apart to refit the glass the original windscreen had rotted away brentnz
rustyreks
PostPosted: Fri Jan 30, 2009 11:04 pm    Post subject: windscreen replacement Reply with quote
What i have heard of is guys using two ford 8 or 10 screens and cutting
and brasing them together as made of brass if you cant find a suitable
replacement worth considering rustyreks
1.5ran
PostPosted: Wed May 20, 2009 10:32 pm    Post subject: Reply with quote
I have a friend who needs one of these or the one he has got repairing,or he has heard of some one who can make one in brass,what would you expect the cost of that to be?would any one else be interested is there any demand I was really surprised to find as much info here he was delighted when I told him. How many van versions are around ?Any advice on this surround would be great.
PostPosted: Wed May 20, 2009 10:39 pm    Post subject: Reply with quote
I have a rotten frame or two somewhere here, not sure where though! they will need repairing or making a good one from the two at some point.
Not sure on the brass one, it could be quite dear, witht he price of brass, and the extrusion or cross section is quite a complicated one if he is going to try and match that. Would be interested to know how much they cost should he find out?
There are plenty of e83W's both vans, pickups and other coach built examples, so there could be people interested in a brass one, could be worth asking in the ford sidevalve club magazine?
1.5ran
PostPosted: Wed May 20, 2009 10:52 pm    Post subject: Reply with quote
Thanks for the reply buzzy Very Happy you have done a very good job of yours,my other half is concidering repairing the friends one,but if an easier option is available saves the hassle & if brass ones would be popular may be worth having a batch made up,they would look nice in brass Cool The guy just needs one to use as a pattern for the brass ones,I will tell my friend.
PostPosted: Thu May 21, 2009 4:34 pm    Post subject: Reply with quote
there have been batches of brass ones made in the past, from memory they were asking £400+ for them
