metal strips for inside a pickup bed
admin
PostPosted: Thu Oct 12, 2006 8:11 pm    Post subject: metal strips for inside a pickup bed Reply with quote
Someone I know is restoring a couple of 50s/60s Chevy pickups, and he's looking for the correct profile strips to go in the rear bed area. They are available in the States, but due to the length required (8ft 1") they wont ship at a reasonable rate. Does anyone know where they can be bought in the UK??
ta
Uncle Joe
PostPosted: Fri Oct 13, 2006 7:57 am    Post subject: Reply with quote
Try Rodley Motors, if they cant get hold of them, nobody can!
Otherwise, it can be time consuming, but they are easy enough to reproduce.
admin
PostPosted: Fri Oct 13, 2006 8:49 am    Post subject: Reply with quote
Ok I've found their details, will pass 'em on
cheers
rustyreks
PostPosted: Mon Nov 27, 2006 8:19 am    Post subject: Reply with quote
Rick the vanguard ute has similar looking steel strips on the back deck as well maybe they were the same for different models you could check with the vanguard club there must be a vanguard club in england maybe there club has spares.
rustyreks
PostPosted: Mon Nov 27, 2006 8:24 am    Post subject: steel strips Reply with quote
Just thought Rick the mouldings would be easy to get made up they would be a rolled pattern someone who has the right shaping tools could make them same type of pattern shape as on the door of the fordson.I have seen the machines they are like a press that you fit different rollers and pass the metal though to be shaped if all else fails.Maybe frosts could make them for him they have the gear to do it.
