admin
Posted: Thu Oct 12, 2006 8:11 pm Post subject: metal strips for inside a pickup bed |
Someone I know is restoring a couple of 50s/60s Chevy pickups, and he's looking for the correct profile strips to go in the rear bed area. They are available in the States, but due to the length required (8ft 1") they wont ship at a reasonable rate. Does anyone know where they can be bought in the UK??
ta
Posted: Fri Oct 13, 2006 7:57 am Post subject: |
Try Rodley Motors, if they cant get hold of them, nobody can!
Otherwise, it can be time consuming, but they are easy enough to reproduce. |
admin
Posted: Fri Oct 13, 2006 8:49 am Post subject: |
Ok I've found their details, will pass 'em on
cheers
RJ |
rustyreks Guest
Posted: Mon Nov 27, 2006 8:19 am Post subject: |
| Rick the vanguard ute has similar looking steel strips on the back deck as well maybe they were the same for different models you could check with the vanguard club there must be a vanguard club in england maybe there club has spares. |
rustyreks Guest
Posted: Mon Nov 27, 2006 8:24 am Post subject: steel strips |
| Just thought Rick the mouldings would be easy to get made up they would be a rolled pattern someone who has the right shaping tools could make them same type of pattern shape as on the door of the fordson.I have seen the machines they are like a press that you fit different rollers and pass the metal though to be shaped if all else fails.Maybe frosts could make them for him they have the gear to do it. |
