DEBUG Message
PostPosted: Wed Feb 14, 2024 8:40 am    Post subject: DEBUG Message Reply with quote
I find that the DEBUG message comes up virtually every time I post. Can I suggest that if it persists Rick could put a sticky post at the top of the list warning about it.
If you ever get it, go back to the index and re-enter the thread and 99% of the time your posting WILL be there.
EDIT
In order to prove the exception to the rule, the DEBUG message stayed away when I posted the above.
PostPosted: Wed Feb 14, 2024 9:35 am    Post subject: Reply with quote
I get the debug message every time, it still enters the post though if I just leave it...
PostPosted: Wed Feb 14, 2024 10:06 am    Post subject: Reply with quote
It's just the forum software is getting on a bit and diverging away from the latest versions of PHP that run on the host server. It's annoying but the only option really is to start the forum over again using the latest version, and that's a non-starter really due to time, costs to do it all over again etc.
PostPosted: Wed Feb 14, 2024 10:09 am    Post subject: Reply with quote
As the error seems to be in the email section (presumably where it looks to see if anyone has requested an email to be sent when a thread is updated) would it be possible to just disable that part? By that I just mean comment it out, rather than looking for some sort of configuration option.
Rusty
PostPosted: Thu Feb 15, 2024 2:19 am    Post subject: Reply with quote
Thanks Rick, for clarifying what is going on!
I don't think it matters much as long as one is aware it's happening, but it certainly caught me out. This was the first time it has happened to me so I will be aware next time.
Mog
PostPosted: Thu Aug 01, 2024 7:33 am    Post subject: Reply with quote
I give up posting ...
bjacko
PostPosted: Thu Aug 01, 2024 7:57 am    Post subject: Bug Reply with quote
I just ignore it.
1985 Rover SD1 VDP
PostPosted: Thu Aug 01, 2024 9:11 pm    Post subject: Reply with quote
Why? just post and ignore the message if it comes up.
PostPosted: Fri Aug 02, 2024 9:33 am    Post subject: Reply with quote
Just ignore that message entirely.
If one wishes to view one's post beforehand, use the 'preview' button....
I find he debug message doesn't always come up if the preview is used first.
However, if one wishes to view one's post in all its glory, as part of the actual thread,then simply go back to the index page, and look it up in the same way one looks up what has recently been posted....
PostPosted: Mon Sep 02, 2024 8:21 am    Post subject: Reply with quote
If you want to post the £ sign use "& # 163 ;" without the spaces between the characters
Vintage Fly Guy
PostPosted: Mon Sep 02, 2024 10:42 pm    Post subject: Reply with quote
ukdave2002 wrote:
If you want to post the ? sign use "& # 163 ;" without the spaces between the characters
£ By George, I think we've got it!
Having said that, it worked when I tried it, then when I edited to add the 'by George bit, it reverted to a ? (question mark).
I then had to edit the comment, delete the question mark and re-type the "& # 163 ;" without the spaces between the characters. So I'll probably just stick to tying the word quid! Laughing
