Unusual coil.
PostPosted: Tue Jan 13, 2026 11:32 am    Post subject: Unusual coil. Reply with quote
This 6 volt 3 amp 'Auto Lite' coil (Ebay) is unlike anything I have seen before. Perhaps someone can explain why there are two HT outlets? Could it be for twin distributors?
PostPosted: Tue Jan 13, 2026 1:29 pm    Post subject: Reply with quote
Probably from a 2 cylinder engine utilising Wasted Spark ignition, eliminates the need for a distributor, possibly from a bike where space is limited.
PostPosted: Tue Jan 13, 2026 2:47 pm    Post subject: Reply with quote
Thanks for that explanation, Dave.
Harley Davidson for example.
Rusty
PostPosted: Wed Jan 14, 2026 12:24 am    Post subject: Reply with quote
I have never actually looked, but someone told me years ago that 2CV Citroens fired the plug on both compression and Exhaust, if that is true then they would be the most common type that might use that style of coil!
norustplease
PostPosted: Wed Jan 14, 2026 10:09 am    Post subject: Reply with quote
I think that a 2CV is a Boxer, ie it fires both cylinders simultaneously. The coil is double ended, there is no distributor as such, just a set of points at the front of the engine attached to the camshaft. It only fires on compression.
1953 Citroen Traction
1964 Volvo PV544
1973 VW Beetle 1303L
Boring Suzuki SX Hybrid
PostPosted: Wed Jan 14, 2026 11:56 am    Post subject: Reply with quote
Both spark plugs fire simultaneously but not both cylinders. The spark firing on the exhaust stroke is wasted.
PostPosted: Wed Jan 14, 2026 12:52 pm    Post subject: Reply with quote
IIRC, the coil is double ended on a duck shoveller
PostPosted: Wed Jan 14, 2026 3:08 pm    Post subject: Reply with quote
Having led a sheltered life...I know what a shoveller duck looks like...but what is a "duck shoveller", please?
PostPosted: Wed Jan 14, 2026 5:49 pm    Post subject: Reply with quote
Hah! Deux Chevaux......Dux chevux...
PostPosted: Wed Jan 14, 2026 9:32 pm    Post subject: Reply with quote
Yes, the coil is double ended. The clever thing, of course, is that there is no distributor; no need.
Such a foolproof design. Like everything about those cars it is designed with reliability at it's heart.
If only they were still being made, the world would at least have some sanity left.
