Brake Master Cylinder
Goto page Previous  1, 2
Vintage Fly Guy
PostPosted: Tue Apr 28, 2026 9:12 pm    Post subject: Reply with quote
Rootes75 wrote:
So, after all, its turns out that the Brake master cylinder is actually a Clutch Master Cylinder.
The lorry was used by a Rootes Dealership in the 40s/50s/60s and apparently during that time the original Lockheed 1" Brake master cylinder was replaced by a 1" bore Lockheed Clutch Master Cylinder.
As its been on there for the last half a century or so and all the pipework and brackets are modified for it we are have sourced a replacement and will go from there.
Well, just goes to show that ingenuity (or ham-fisted gibbonry, you decide!) will live on long after the original perpetrator has hung up their spanners! Are you putting it all back to 'factory spec' or replacing modified like-for-like? Either is part of its history now, so as long as the modification was safe and worked well, then who are we to pick sides?
Rusty
PostPosted: Wed Apr 29, 2026 1:13 am    Post subject: Reply with quote
A lot of times the only difference between a brake and clutch cylinder is the fitting of a residual line pressure valve on the brake cylinder, it's not uncommon to find them fitted that way, especially on Lockheed cylinders. (at least it's not uncommon in country Western Australia)
PostPosted: Wed Apr 29, 2026 8:09 am    Post subject: Reply with quote
Well, the cylinder is roughly a third of the price of the original, and I would have to re-pipe to accommodate the the original back into the system so my plan is to replace with what's been on there for the last few decades.
I mean, it works. It was modified to take it by a Rootes dealership so I presume this might have been a 'get around' back in the day.
PostPosted: Mon May 18, 2026 12:56 pm    Post subject: Reply with quote
We got hold of a new Master Cylinder through Powertrack brakes, we fitted it on Saturday and bled the system through thoroughly....
There's a but...
Still no pressure in the pedal, nothing. We then tried the handbrake and that pulls fully up with no pressure and I led under while it was pulled and the rear brake tree barely moves...
We have a show next weekend so that's now a no go...we will have to get her out the shed and remove the rear wheels and drums to see what is not moving or out of place.
Page 2 of 2
