Goto page Previous  1, 2, 3 ... 121, 122, 123, 124  Next
PostPosted: Thu Jul 09, 2026 11:38 am    Post subject: Reply with quote
If its a Ray described; CPU operates a relay directly, it would be easy to add or try a remote pump, if its on a CAN it may be more tricky as there may be some acknowledgement required from the pump module.
Given the age of the car its probably the former.
PostPosted: Thu Jul 09, 2026 12:18 pm    Post subject: Reply with quote
These cars do have a CAN but at this point in time the fuel pump had not yet been integrated.
I have been mulling this over and in my clumsy way what I am trying to say is that the ECU doesn't know one pump from another... so if the wires that go to the old pump are sent to the new 'in line' one it should be O.K.
(Famous last words of course)
. Razz
PostPosted: Thu Jul 09, 2026 3:59 pm    Post subject: Reply with quote
One could always disconnect, if reachable, the wires from the in tank pump connections, plug them into a suitable clacky electric high pressure pump, and see if it clacks with ignition turned on?
PostPosted: Thu Jul 09, 2026 4:36 pm    Post subject: Reply with quote
I am sure you are right. I don't see why it would not work. One might even regard it as an improvement!
I should have done that when my Range Rover petrol pump failed but it would have involved spoiling the fitted interior. In the end I just let a Land Rover specialist replace the pump from underneath. It needed a lift to raise the car high enough off the ground to allow the tank to drop down so the pump could be extracted from it.
PostPosted: Thu Jul 09, 2026 5:01 pm    Post subject: Reply with quote
I'd first check the relay, including is there a demand on it (which I'm sure Rick will have already done), if its working, pop it out, quirt 12v down the relay output and see if its drawing any current, if yes and there is no fuel pressure then it looks as if the pump has a mechanical fault, if no current draw then we either have a faulty connection or electrical fault with the pump. Narrowing it down is how to solve electrical faults.
PostPosted: Sat Jul 11, 2026 8:01 am    Post subject: Reply with quote
I've checked fuses and swapped out relays but to no avail so far.
Today's upload sees us at Telford Steam Railway for their Rover cars day, with examples from the 1920s through to the 1990s turning up. Plus a ride on a steam train, naturally.
https://youtu.be/MmGpnn0I_uI
PostPosted: Tue Jul 14, 2026 8:16 am    Post subject: Reply with quote
Morning all, last month's Tern Hill meet-up saw all sorts of vehicles turn up despite the weather forecast being less-than-glittering.
https://youtu.be/HEHJQJT3RpU
PostPosted: Thu Jul 16, 2026 8:33 am    Post subject: Reply with quote
Hi, in today's video I'm over near Runcorn to check out the cars entered into the imminent Manor Park Classics auction.
https://youtu.be/nUkr0JzYtGI
PostPosted: Fri Jul 17, 2026 4:24 pm    Post subject: Reply with quote
Afternoon all, latest additions to the calendar store covers Daimler and Jaguar XJS/XJ-S.
https://www.oldclassiccar.co.uk/calendars.htm
PostPosted: Sat Jul 18, 2026 7:28 am    Post subject: Reply with quote
Morning all, this weekend's upload sees us dive in on the '31 Minor to see if it'll run and drive.
https://youtu.be/T9YONNxVutQ
PostPosted: Wed Jul 22, 2026 8:33 am    Post subject: Reply with quote
Morning, in today's upload we're at a Jensen Owners' Club meet where we ogle a number of fine cars and chat to their owners.
https://youtu.be/jtHzIVs0bgQ
PostPosted: Thu Jul 23, 2026 6:37 pm    Post subject: Reply with quote
Quick video of a very surprising visitor to last Sunday's Combermere meet, an original Barris-built Batmobile.
https://youtu.be/pQelT-PKRf4
PostPosted: Sat Jul 25, 2026 9:22 am    Post subject: Reply with quote
In today's upload we're off in the MG to a very civilised gathering held at a small farm grass airstrip, which combined an aircraft fly-in (Tiger Moths & later) with various old cars and other vehicles in the adjoining field. All very pleasant.
https://youtu.be/T6DKRygdKqk
PostPosted: Tue Jul 28, 2026 7:52 am    Post subject: Reply with quote
Morning, yesterday we spent a few hours poring over the 200+ entries entered into the next Brightwells auction, the preview video has now gone live.
https://youtu.be/NDxuCKB8fZU
PostPosted: Tue Jul 28, 2026 12:41 pm    Post subject: Reply with quote
I quite like the late 30's Morris 12. A chap we always used to see at our local show had one. Very nice cars.
Page 122 of 124
