Couple of old garage workshop tools
PostPosted: Tue Feb 05, 2008 8:58 pm    Post subject: Reply with quote
I'm just getting a little red X and when I right click then click show picture, I just get the words without even the X. Sad Sad Sad Sad
PostPosted: Tue Feb 05, 2008 9:15 pm    Post subject: Reply with quote
Same problem...
PostPosted: Tue Feb 05, 2008 9:19 pm    Post subject: Reply with quote
nothing to do with fitting and removing tyres I suppose?
PS the image worked earlier on, photobucket must be throwing a wobbler
Uncle Joe
PostPosted: Tue Feb 05, 2008 9:24 pm    Post subject: Reply with quote
Quite right Rick, its nothing to do with fitting tyres. Laughing
PostPosted: Tue Feb 05, 2008 9:28 pm    Post subject: Reply with quote
I'm sure I would know what it is if I could see it Confused
Just checked... Photobucket seems to be down.
Uncle Joe
PostPosted: Tue Feb 05, 2008 9:59 pm    Post subject: Reply with quote
I'm pretty well sure that there is at least one person on the forum that will know exactly what it is used for. Trouble is, hes not seen the thread yet...maybe I should pm him?
PostPosted: Tue Feb 05, 2008 11:22 pm    Post subject: Reply with quote
It's back up now.
It's a "crown cap remover". Laughing Laughing Laughing Laughing Laughing Laughing
PostPosted: Tue Feb 05, 2008 11:38 pm    Post subject: Reply with quote
I made up something similar to remove the clutch thrust bearing from a Ford type 9 gearbox. Confused don't s'pose it's that though Confused
Uncle Joe
PostPosted: Wed Feb 06, 2008 10:41 am    Post subject: Reply with quote
Penman: If the bottles with crown caps that size hold beer, can I have some please? Laughing Laughing
Pigtin: Quite right, its not that either. Very Happy
62rebel
PostPosted: Thu Feb 07, 2008 4:53 am    Post subject: Reply with quote
UJ, why do you have an upper control arm holder for a Mustang?
that exact item is depicted in most repair manuals as a must-have for home repairs to Fords with the coil spring atop the upper control arm, as it wedges between the arm and the subframe. personally, i don't use one when doing work on the front end as i seem to need as much room as possible to swing that enormous hammer around....
Uncle Joe
PostPosted: Thu Feb 07, 2008 8:27 am    Post subject: Reply with quote
62rebel, congratulations. The reason I have it is because 1) I needed some welding practice, and 2) I used to have a 428 Mustang...
62rebel
PostPosted: Fri Feb 08, 2008 4:45 am    Post subject: Reply with quote
i always thought that for every MG, Triumph, or Jaguar sold here that we should have exported an equal number of Detroit cars into Olde England, apparently some numbers did make it through! i didn't know, however, that you were personally responsible for the majority of them!
wrinx
PostPosted: Mon Jun 23, 2008 9:00 pm    Post subject: Reply with quote
Another home made copy of a 1950s tool....any ideas?
(no right clicking for clues! Smile)
wrinx
www.alfaromeo155.co.uk | www.alfamatta.co.uk
PostPosted: Mon Jun 23, 2008 9:27 pm    Post subject: Reply with quote
It has to be a Prangling Iron. Wink
wrinx
PostPosted: Mon Jun 23, 2008 10:32 pm    Post subject: Reply with quote
S'what? Confused
wrinx
Page 2 of 3
