Posted: Tue Feb 05, 2008 8:58 pm Post subject: |
I'm just getting a little red X and when I right click then click show picture, I just get the words without even the X.  |
Posted: Tue Feb 05, 2008 9:15 pm Post subject: |
| Same problem... |
Uncle Joe Guest
Posted: Tue Feb 05, 2008 9:24 pm Post subject: |
Quite right Rick, its nothing to do with fitting tyres.  |
Posted: Tue Feb 05, 2008 9:28 pm Post subject: |
I'm sure I would know what it is if I could see it
Just checked... Photobucket seems to be down. |
Uncle Joe Guest
Posted: Tue Feb 05, 2008 9:59 pm Post subject: |
| I'm pretty well sure that there is at least one person on the forum that will know exactly what it is used for. Trouble is, hes not seen the thread yet...maybe I should pm him? |
Posted: Tue Feb 05, 2008 11:22 pm Post subject: |
It's back up now.
It's a "crown cap remover".  |
Posted: Tue Feb 05, 2008 11:38 pm Post subject: |
I made up something similar to remove the clutch thrust bearing from a Ford type 9 gearbox. don't s'pose it's that though  |
Uncle Joe Guest
Posted: Wed Feb 06, 2008 10:41 am Post subject: |
Penman: If the bottles with crown caps that size hold beer, can I have some please?
Pigtin: Quite right, its not that either.  |
62rebel
Joined: 03 Dec 2007 Posts: 343 Location: Charleston, South Carolina
Posted: Thu Feb 07, 2008 4:53 am Post subject: |
UJ, why do you have an upper control arm holder for a Mustang?
that exact item is depicted in most repair manuals as a must-have for home repairs to Fords with the coil spring atop the upper control arm, as it wedges between the arm and the subframe. personally, i don't use one when doing work on the front end as i seem to need as much room as possible to swing that enormous hammer around.... |
Uncle Joe Guest
Posted: Thu Feb 07, 2008 8:27 am Post subject: |
| 62rebel, congratulations. The reason I have it is because 1) I needed some welding practice, and 2) I used to have a 428 Mustang... |
62rebel
Posted: Fri Feb 08, 2008 4:45 am Post subject: |
| i always thought that for every MG, Triumph, or Jaguar sold here that we should have exported an equal number of Detroit cars into Olde England, apparently some numbers did make it through! i didn't know, however, that you were personally responsible for the majority of them! |
wrinx
Posted: Mon Jun 23, 2008 9:00 pm Post subject: |
Another home made copy of a 1950s tool....any ideas?
(no right clicking for clues! )
wrinx _________________ www.alfaromeo155.co.uk | www.alfamatta.co.uk
Posted: Mon Jun 23, 2008 9:27 pm Post subject: |
It has to be a Prangling Iron.  |
wrinx
Posted: Mon Jun 23, 2008 10:32 pm Post subject: |
S'what?
