Uncle Joe Guest
Posted: Sat May 03, 2008 9:57 am Post subject: Oops! |
I dont think this should look like this, but how it happened is a complete mystery to me. I wonder if anyone can recognise what it was?
Greeney in France
Posted: Sat May 03, 2008 10:47 am Post subject: |
Looks like an inner drive shaft bearing?
OR now I have had a second look a gear lever socket _________________ www.OldFrenchCars.com
Uncle Joe Guest
Posted: Sat May 03, 2008 12:52 pm Post subject: |
| Its neither...the bent bit on the right should be straight.... |
Posted: Sun May 04, 2008 11:00 am Post subject: |
I've never seen one before and it's difficult to gauge its size, but is it the end of a speedo cable?
Peter |
Uncle Joe Guest
Posted: Sun May 04, 2008 11:05 am Post subject: |
Spot on Peter! Its the transmission end of the outer casing.
I still dont know how it got damaged though.... |
Job-Rated
Posted: Sun May 04, 2008 2:12 pm Post subject: |
| Uncle Joe wrote: | | I still dont know how it got damaged though.... |
Drivin' too bloomin' quick, I shouldn't wonder...  _________________ Don't run your fingers over my truck & I won't run my truck over your fingers!
Uncle Joe Guest
Posted: Sun May 04, 2008 2:19 pm Post subject: |
As if I would!  |
Brian M
Posted: Tue May 06, 2008 2:02 pm Post subject: |
UJ
It is caused either
1. by the "torque twist" on your V8 rotating the gearbox and taking up all the slack in the speedo cable.
2. going over a speed bump too fast and the bulkhead (and therefore dashboard) moving relative to the drivetrain and again the speedo cable having no slack left.
or
3. you hit it with a screwdriver! _________________ Brian
Uncle Joe Guest
Posted: Tue May 06, 2008 2:13 pm Post subject: |
| Brian, I only wish it was as simple as that. At least then I would know what had happened! |
