Uncle Joe Guest
Posted: Thu May 08, 2008 1:34 pm Post subject: |
Yes, thats the one I meant. I was just giving it the almost correct name!  |
Job-Rated
Posted: Thu May 08, 2008 10:40 pm Post subject: |
...And radiator cap...
 _________________ Don't run your fingers over my truck & I won't run my truck over your fingers!
Norfolkandchance
Posted: Fri May 09, 2008 2:13 pm Post subject: |
Job-Rated wrote: | ...And radiator cap...
Think I can get that one myself  |
Uncle Joe Guest
Posted: Fri May 09, 2008 2:51 pm Post subject: |
...and your starter for ten, where is the thermostat? |
Old-Nail
Posted: Fri May 09, 2008 3:29 pm Post subject: |
Norfolkandchance wrote: | Job-Rated wrote: | ...And radiator cap...
So did my brother as he filled his radiator with engine oil  |
Norfolkandchance
Posted: Fri May 09, 2008 3:38 pm Post subject: |
Old-Nail wrote: | Norfolkandchance wrote: | Job-Rated wrote: | ...And radiator cap...
Oil goes through cap located on green engine block, radiator is the cap infront of it as radiator is at the front of the car to maximise cooling air as it enters through grille.
How am I doing????? |
Norfolkandchance
Posted: Fri May 09, 2008 3:39 pm Post subject: |
Uncle Joe wrote: | ...and your starter for ten, where is the thermostat? |
Err..... Umm.... need to look at pic again |
Norfolkandchance
Posted: Fri May 09, 2008 3:40 pm Post subject: |
I guess it will be in the part labelled very kindly for me call thermostat housing
Think that is called cheating |
Uncle Joe Guest
Posted: Fri May 09, 2008 3:56 pm Post subject: |
...and your bonus for 20, can you repair the thermostat housing with gaff-er tape? |
Norfolkandchance
Posted: Fri May 09, 2008 4:15 pm Post subject: |
Uncle Joe wrote: | ...and your bonus for 20, can you repair the thermostat housing with gaff-er tape? |
No idea. But in my books unless its a temporary, get you home repair - that's called a bodge up to me and it should be replaced not repaired. |
Joined: 23 Nov 2007 Posts: 4863 Location: Swindon, Wilts.
Posted: Fri May 09, 2008 7:45 pm Post subject: |
1 place which can leak is the under the washers where the rocker box bolts are, The big hexagons on top of the box particulary the one next to the Morris badge because that is at the dirtier end on those piccies.
Another thing to check is the pipe from the top of the rocker box into the aircleaner, that is a breather pipe which should allow excess pressure and any oil fumes into the inlet system to get burnt instead fo dripping oil, but if it is blockedat all this will increase pressure inside the block and increase the likelyhood of causing leaks at weak seals. |
