NFC's Morris Minor (was:"Uncle Joe")
Goto page Previous  1, 2
PostPosted: Thu May 08, 2008 1:29 pm    Post subject: Reply with quote
I've added the carb dashpot filler cap now if thats the one you mean? (you may need to refresh the thread to see it)
Uncle Joe
PostPosted: Thu May 08, 2008 1:34 pm    Post subject: Reply with quote
Yes, thats the one I meant. I was just giving it the almost correct name! Laughing
Job-Rated
PostPosted: Thu May 08, 2008 10:40 pm    Post subject: Reply with quote
...And radiator cap... Rolling Eyes
Laughing Laughing
Norfolkandchance
PostPosted: Fri May 09, 2008 2:13 pm    Post subject: Reply with quote
Laughing Laughing
Think I can get that one myself Laughing
Uncle Joe
PostPosted: Fri May 09, 2008 2:51 pm    Post subject: Reply with quote
...and your starter for ten, where is the thermostat?
Old-Nail
PostPosted: Fri May 09, 2008 3:29 pm    Post subject: Reply with quote
Norfolkandchance wrote:
Laughing Laughing
So did my brother as he filled his radiator with engine oil Laughing
Norfolkandchance
PostPosted: Fri May 09, 2008 3:38 pm    Post subject: Reply with quote
Laughing Laughing
Oil goes through cap located on green engine block, radiator is the cap infront of it as radiator is at the front of the car to maximise cooling air as it enters through grille.
How am I doing?????
Norfolkandchance
PostPosted: Fri May 09, 2008 3:39 pm    Post subject: Reply with quote
Err..... Umm.... need to look at pic again
Norfolkandchance
PostPosted: Fri May 09, 2008 3:40 pm    Post subject: Reply with quote
I guess it will be in the part labelled very kindly for me call thermostat housing Laughing Laughing Laughing
Think that is called cheating
Uncle Joe
PostPosted: Fri May 09, 2008 3:56 pm    Post subject: Reply with quote
...and your bonus for 20, can you repair the thermostat housing with gaff-er tape?
Norfolkandchance
PostPosted: Fri May 09, 2008 4:15 pm    Post subject: Reply with quote
No idea. But in my books unless its a temporary, get you home repair - that's called a bodge up to me and it should be replaced not repaired.
PostPosted: Fri May 09, 2008 7:45 pm    Post subject: Reply with quote
1 place which can leak is the under the washers where the rocker box bolts are, The big hexagons on top of the box particulary the one next to the Morris badge because that is at the dirtier end on those piccies.
Another thing to check is the pipe from the top of the rocker box into the aircleaner, that is a breather pipe which should allow excess pressure and any oil fumes into the inlet system to get burnt instead fo dripping oil, but if it is blockedat all this will increase pressure inside the block and increase the likelyhood of causing leaks at weak seals.
PostPosted: Wed Aug 27, 2008 9:38 am    Post subject: Reply with quote
Hi NFC, a few months into classic ownership now, how's the Minor doing?
Rick Smile
Page 2 of 2
