compressions and broken ring
Timstopp
PostPosted: Sun May 03, 2009 6:47 pm    Post subject: compressions and broken ring Reply with quote
Having been out and about on the drive it day, and having suffered a few "issues" I did a compression test this morning - the results of which were 111, 112,115, 90 psi on a cold engine, so I have dropped the sump and removed the lowest piston. When it came out 1/2 of one of the piston rings was missing (bits of it in the sludge in the sump. Now, can I source just a piston ring of the correct dimensions ie 60mm and rectangle profile and fit this straight back? and does anyone know where I might get one?
I know to do a "proper" job I should hone the cylinder, but I don't want to take the head off, and also I suspect that would then put this cylinder's compression above the others. I hope that although the readings are low, if they are equalish it should be ok
Wolseley Nine 1934 Morris 8 tourer 1936
PostPosted: Mon May 04, 2009 3:01 pm    Post subject: Reply with quote
Hi Tim,
I think you'll be able to get rings from http://www.cpearsonpistons.co.uk/index2.html
If not he'll probably know where you can try.
1939 SS Jaguar 2 litre saloon
Timstopp
PostPosted: Tue May 05, 2009 9:29 am    Post subject: Reply with quote
Thanks, I tried but he does not have any, nor does he know anyone who might. - they are 60mm pistons, +020. Does any one have any idea's?
PostPosted: Tue May 05, 2009 9:34 am    Post subject: Reply with quote
you could try Lancaster Vintage, they might have something. If push comes to shove and they simply aren't available, you could get some made up as happened with my Dodge's lump.
Rick (OCC Admin)
Kelsham
PostPosted: Tue May 05, 2009 11:17 am    Post subject: piston rings Reply with quote
Hi I have had similiar problems getting rings for my 1932 BSA Vtwin Trike engine.
Eventually I tried my local engine rebuilder and they widened the gap the ring seats in and supplied wider rings.
This has worked well for the last few years. regards Kels.
Timstopp
PostPosted: Tue May 05, 2009 2:51 pm    Post subject: Reply with quote
Rick - where did you get your rings made up, as it looks like I might have to go down this route. I have a full set of +30 and +40 pistons, so I could re-bore and use these but this seems silly as the engine does not warrant a full rebore, just for one ring!
(unfortunately the other pistons have different ring designs)
PostPosted: Tue May 05, 2009 5:17 pm    Post subject: Reply with quote
Hi Tim
The new rings were sourced from somewhere during the engine's rebuild, you could have a word with Henry Arnett (address and contact details are on the page below), who did the rebuild, he might be able to sort something for you.
http://www.oldclassiccar.co.uk/dodge_rebuild/part19_enginerebuild.htm
Rick (OCC Admin)
