2 pak primer!
PostPosted: Thu Sep 24, 2009 11:48 pm    Post subject: 2 pak primer! Reply with quote
If I have a primed surface, can you top coat in 2 pak, or does it have to be a 2 pak primer?
bob2
PostPosted: Fri Sep 25, 2009 10:11 am    Post subject: Reply with quote
I have used 2 pack directly on red oxide without any problem so far and its been on for more than a year now though its not exposed to the elements!!
peppiB
PostPosted: Fri Sep 25, 2009 1:53 pm    Post subject: Reply with quote
I was told that 2 pack would happily go over cellulose, but not cellulose over 2 pack. My 1800 was sprayed in 2 pack covering cellulose primer, and after a year there are no signs of any problems
PostPosted: Fri Sep 25, 2009 2:45 pm    Post subject: Reply with quote
Yep you can use 2 pack top coat over acrylic /celly primer.
PostPosted: Fri Sep 25, 2009 8:14 pm    Post subject: Reply with quote
Celly goes really well over hardened 2 pack as long as you can finish the edge on line or swage as it does not blend/flow in
Rover P2
Morris Mini Traveller Mk2
PostPosted: Fri Sep 25, 2009 10:47 pm    Post subject: Reply with quote
Excellent, thanks! Very Happy
