captinbash
Posted: Sun Jul 04, 2010 5:18 pm Post subject: Peak Hitch Damper??? |
Has anyone here any experience of the Peak hitch damper fitted to a late 70's Viking? Mine has started to bang when braking hard but not so much on pulling away, I can see the rear mounting bolt but the damper then goes into the hitch tube and I can't see any other mounting bolt, sorry to be so thick but help is needed again . Thanks in advance.
David |
WLC4EVA Guest
WLC4EVA Guest
Posted: Fri Jul 16, 2010 9:18 am Post subject: |
The 'other bolt' is the rear bolt that hold the coupling head to the draw tube Capt.
Kind Regards, WLC4Eva |
captinbash
Posted: Fri Jul 16, 2010 7:06 pm Post subject: |
| There are no bolts holding the hitch head onto the tube it appears to be one unit, and peak say they have no knowledge of the older units. thanks for your help though. |
WLC4EVA Guest
Posted: Fri Jul 16, 2010 7:49 pm Post subject: |
I'm sorry Capt., I wasn't much help was I?
More precisely, I wasn't any help at all.
I recently wasted a great deal of time trying to get a non-standard damper, it was a total no-no.
Have you considered getting a period replacement coupling?
A replacement (new) draw tube, coupling head, and weight appropriate damper?
Or even a complete new coupling?
Dampers are pretty important since they control your van brakes.
Kind Regards, WLC |
European Voyager
Posted: Mon Jul 19, 2010 7:21 pm Post subject: |
| Ive got a peak chassis book that came with my caravan , its a 1972 ish viking , ill look at mine and look at the book nd let you know . if you like. |
captinbash
Posted: Mon Jul 19, 2010 7:42 pm Post subject: |
| Thanks WLC for your help, I will just have to hope something turns up. |
captinbash
Posted: Mon Jul 19, 2010 7:43 pm Post subject: |
European Voyager, thats a kind offer. I have sent you a pm.
Thanks |
captinbash
Posted: Tue Jul 20, 2010 6:49 pm Post subject: |
Ok, Damper removed now, I just have to find a replacement all good fun and an enjoyable learning curve  |
