Peak Hitch Damper???
captinbash
PostPosted: Sun Jul 04, 2010 5:18 pm    Post subject: Peak Hitch Damper??? Reply with quote
Has anyone here any experience of the Peak hitch damper fitted to a late 70's Viking? Mine has started to bang when braking hard but not so much on pulling away, I can see the rear mounting bolt but the damper then goes into the hitch tube and I can't see any other mounting bolt, sorry to be so thick Rolling Eyes but help is needed again Crying or Very sad . Thanks in advance.
David
WLC4EVA
PostPosted: Thu Jul 15, 2010 6:13 pm    Post subject: Reply with quote
Have you tried Peak Trailers?
http://www.vrsystems.co.uk/peakt/products.asp_category=Couplings&subcategory=DeltaCoupling.html
Kind Regards, WLC4Eva
WLC4EVA
PostPosted: Fri Jul 16, 2010 9:18 am    Post subject: Reply with quote
The 'other bolt' is the rear bolt that hold the coupling head to the draw tube Capt.
captinbash
PostPosted: Fri Jul 16, 2010 7:06 pm    Post subject: Reply with quote
There are no bolts holding the hitch head onto the tube it appears to be one unit, and peak say they have no knowledge of the older units. thanks for your help though.
WLC4EVA
PostPosted: Fri Jul 16, 2010 7:49 pm    Post subject: Reply with quote
I'm sorry Capt., I wasn't much help was I?
More precisely, I wasn't any help at all.
I recently wasted a great deal of time trying to get a non-standard damper, it was a total no-no.
Have you considered getting a period replacement coupling?
A replacement (new) draw tube, coupling head, and weight appropriate damper?
Or even a complete new coupling?
Dampers are pretty important since they control your van brakes.
Kind Regards, WLC
European Voyager
PostPosted: Mon Jul 19, 2010 7:21 pm    Post subject: Reply with quote
Ive got a peak chassis book that came with my caravan , its a 1972 ish viking , ill look at mine and look at the book nd let you know . if you like.
captinbash
PostPosted: Mon Jul 19, 2010 7:42 pm    Post subject: Reply with quote
Thanks WLC for your help, I will just have to hope something turns up.
captinbash
PostPosted: Mon Jul 19, 2010 7:43 pm    Post subject: Reply with quote
European Voyager, thats a kind offer. I have sent you a pm.
Thanks
captinbash
PostPosted: Tue Jul 20, 2010 6:49 pm    Post subject: Reply with quote
Ok, Damper removed now, I just have to find a replacement Rolling Eyes all good fun and an enjoyable learning curve Laughing
