traction39
Posted: Mon Jul 12, 2010 10:53 am Post subject: |
Just a thought, are you sure that the fittings are UNC and not BSW? I thought UNC and BSW threads matched and made up OK. However, their form is slightly different. Are not 1/2" UNC/BSW the exception 12TPI and 13TPI?
Disclaimer! These are brakes and need to be correct!!!
Alistair |
michael1703
Posted: Mon Jul 12, 2010 12:14 pm Post subject: |
have you tried automec?
01280 822818
or
past parts
01284 750729 |
WLC4EVA Guest
Posted: Sun Jul 18, 2010 9:34 am Post subject: |
[color=white].
Seems a very odd size.
Have you tried?
speedbleeder@earthlink.net
Kind Regards, WLC |
Joined: 23 Nov 2007 Posts: 4285 Location: South Cheshire
Posted: Sun Jul 18, 2010 11:06 am Post subject: |
If you get stuck give me a shout and I can make them for you, I had to make all the bleed screws and cylinder screws for the morris 8 as they are a really odd size (whitworth spanner size with UNF threads!!)
To improve things I made them up in stainless steel.
Given the US origins I doubt if the threads would be BSW, although 3/8 BSW & UNC have the same pitch, the angle and depth of the thread are different, so should not be mixed!
stuchamp
Posted: Fri Jul 30, 2010 1:50 pm Post subject: |
They are almost certain to be UNC,I doubt if any US made vehicle uses Whit threads anywhere,although I've seen some with odd BA fittings.
As someone else has pointed out the threads are close enough that the bolts can be swapped over but tighteneing them will almost certainly strip the threads.
A decent quality thread gauge is a good investment for anyone messing about with old cars or bikes. _________________ Thirty years selling imperial hand tools for old machinery(Now happily retired). |
stuchamp
Posted: Fri Jul 30, 2010 4:53 pm Post subject: |
| Glad you found them. I may actually have a pair here along with the front backing plates, cylinders, etc. Need to dig thru the back shed again. |
