Car-Nut
Posted: Wed Aug 11, 2010 5:41 pm Post subject: Removing my Triple SU's |
Just removing my carbs as often the case the last nut in the most akward place wasnt coming off
Once I realised it was turning the stud out and it was fully out, I wiggled the setup forward and put loctite on the stud and screwed it back in.
My problem is my Loctite is German and so are the instructions on the tube How long does it take to cure before I can take the nut off the stud again
 _________________ Car-Nut
'62 S1 Jaguar E-Type 3.8 FHC
'70 420G - 13th from last RHD
'70 420G - 17th from last RHD |
michael1703
Posted: Wed Aug 11, 2010 6:58 pm Post subject: |
mine did that, i just left the nut on the stud and screw the stud back in when refitting
buy a handfull of 5/16ths brass manifold nuts, they look smarter and dont get stuck |
Car-Nut
Posted: Wed Aug 11, 2010 8:10 pm Post subject: |
Cheers Michael, good idea
how's yours going Used it much this year  _________________ Car-Nut
michael1703
Posted: Wed Aug 11, 2010 8:29 pm Post subject: |
mines going well apart from burning quite a bit of oil
it failed its MOT on the front V rubbers but has behaved itself otherwise, only managed about 600 miles so far due to work/price of fuel |
Car-Nut
Posted: Wed Aug 11, 2010 8:51 pm Post subject: |
Sorry to be a bit green, but on a 4.2 XK engine what's the burning a lot of oil down to  _________________ Car-Nut
Nic Jarman
Posted: Thu Aug 12, 2010 10:31 am Post subject: |
I have asked this question before (elsewhere) and could not get an answer so here we go again.
With the 2 front float bowls being infront of the carb body does the car suffer from fuel starvation under heavy or maybe not so heavy braking? _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
victor 101
Posted: Thu Aug 12, 2010 3:55 pm Post subject: |
| Highly unlikely as the fuel is drawn from the bottom of the float chamber and with the float resting on the top there isnt really anywhere for it to go. |
