montreal
Posted: Mon Dec 27, 2010 8:27 pm Post subject: silentbloc bushes |
when did silentbloc bushes first appear on private cars?
i have to mount new friction shocks on my car , replacing the "fix" that some bright spark did with non-standard hydraulic lever type.
john |
Joined: 23 Nov 2007 Posts: 4333 Location: South Cheshire
Posted: Thu Dec 30, 2010 10:05 am Post subject: |
The Morris 8 series E had them, so were used in the late 1930's.
Kelsham
Posted: Thu Dec 30, 2010 4:30 pm Post subject: silentbloc bushes |
My 1931 Bsa Vee twin four wheeler has them on the rear springs.
Any advances on this?
Regards Kels. |
traction39
Posted: Thu Dec 30, 2010 4:53 pm Post subject: |
It is probably difficult to find anything earlier than that...assuming they are the original bushes!
I guess the predecessor would have been rubber bushes, without the external metal casing as in original Andre Hartford shocks. i.e. not Silentblocs.
Citroen had them from 1934/35. |
Salopian
Posted: Thu Dec 30, 2010 10:23 pm Post subject: |
The dreadful Austin 12/6 (March 1931 reg JF 1670 which the web tells me is now on a BMW of some sort!) had the remains of these in the spring eyes in 1967 so i guess 1930 ish is about right.
Bought it for £12.50 in 1967 - 15 mpg and about 55 mph flat out. Sold to a bloke in Grantham in around 1975 after it had festered in my shed for a few years.
I suspect before their invention (and of course they were a cheap alternative) was a proper bronze or brass bush and a steel pin. _________________ Jonathan Butler
Nic Jarman
Posted: Sun Jan 02, 2011 4:25 pm Post subject: |
The Talbot has them on the suspension eyes and that was designed in 1925. _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
montreal
Posted: Mon Jan 03, 2011 3:25 pm Post subject: silent bloc bushes |
many thanks for the replies; that helps me decide!
john  |
