Rover...?
PostPosted: Tue Aug 02, 2011 3:05 pm    Post subject: Rover...? Reply with quote
12hp Rover circa 1920 has been suggested for this one, correct?
PostPosted: Thu Aug 04, 2011 10:19 am    Post subject: Reply with quote
Rick, as no-one else has offered an opinion, here is what I see.
The body could be one of several cars of the period, as can the wheels, which look like Sankeys to me. Even the lamps are generic (C.A.V.?)rather than make-specific.
Rover had a distinctive shape at the header tank to core joint on the radiator, it was 'stepped' at the corners, representing the upper part of a shield. The photo is not quite the right angle to prove or disprove, in a definite way, existence of the steps, however there is no real evidence of them.
At one point I thought maybe a Crossley, but even though it has a moulding on the top tank just below the filler neck, it lacks the 'dip' in the centre of the tank/core junction.
Still hunting!
Salopian
PostPosted: Thu Aug 04, 2011 10:45 pm    Post subject: Reply with quote
Of course it is correct Rick because I suggested it on the VSCC site! The give away is the mounting of the headlights to the radiator shell.
I'll buy you a pint or two if I'm wrong ----
Jonathan Butler
PostPosted: Fri Aug 05, 2011 7:47 am    Post subject: Reply with quote
Smile
PostPosted: Sat Aug 06, 2011 6:11 am    Post subject: Reply with quote
I may be wrong but the body looks too rounded for a Rover
Some early Rover adverts here (scroll to the bottom of the page)
ROVER
One of Britain's Fine Cars
