AC oil filters new old stock what car ar they for?
kitisuru
PostPosted: Thu Dec 01, 2011 10:15 am    Post subject: AC oil filters new old stock what car ar they for? Reply with quote
Hi,
I have a number of AC filters type FZ3 in a metal canister, but I do not know what they fit, can anybody help identifying them. They need to go to someone who can use them!
Dimensions are: Height 12 cm, diameter 9 cm.
Thank you!
(alt+p)
(alt+p)
(alt+p)
PostPosted: Thu Dec 01, 2011 10:22 am    Post subject: Reply with quote
They remind me of Austin A30, early Morris Minor (803cc), and I think Standard 10 although it's hard to be sure on the size.
Welcome to the forum!
Churchill Johnson
PostPosted: Thu Dec 01, 2011 11:23 pm    Post subject: Reply with quote
This looks the type that could be fitted as an after market part of a kit to the old sit up and beg Ford pops.
Scotty
PostPosted: Fri Dec 02, 2011 8:06 am    Post subject: Reply with quote
I'm with CJ - looks like Pop / Anglia ones to me. Wink
PostPosted: Fri Dec 02, 2011 9:01 am    Post subject: Reply with quote
Ooops yep they do look like Ford Pop, A40 Somerset/Devon, Vauxhall 10/12 etc, bigger than the A30/Minor ones I initially thought. I've a few in the garage originally bought for the Devon that I hung onto for the Bedford ute.
PostPosted: Fri Dec 02, 2011 6:12 pm    Post subject: Reply with quote
I reckon with that fitting they are by-pass filters, which may or may not be aftermarket. If so they must never be adapted to fit a full flow filter system.
kitisuru
PostPosted: Sat Dec 03, 2011 12:15 pm    Post subject: thank you Reply with quote
Thank you everybody for your replies, this has helped a lot, hopefully I will be able to find a good home for them now...
P3steve
PostPosted: Sat Dec 03, 2011 5:17 pm    Post subject: Reply with quote
They look like the one fitted to my P3 Rover have you got the overall size of them, what are you looking to get for them?
kitisuru
PostPosted: Sat Dec 03, 2011 6:47 pm    Post subject: size Reply with quote
Let me know if it matches!
PostPosted: Sun Dec 04, 2011 4:47 am    Post subject: Reply with quote
It might be worth investing in this catalogue:
http://www.ebay.com/itm/AC-Delco-filters-catalogue-oil-air-fuel-1967-/350461360462?pt=UK_CarParts_Vehicles_Manuals_Litterature_ET&hash=item51991ff94e
which would hopefully give you the answer. I think it's a scanned image file download, not a real, oily, curly & smelly old book.
2002 MINI Cooper 'S'
Inglewood
PostPosted: Sun Dec 04, 2011 10:24 am    Post subject: Reply with quote
The filter body is typical size/colour of early canister types from AC. However, the connector size is not sufficient to be a full-flow. It is not an engine-mounted unit, it is fitted to the inner wing connected by pipes.
The filter appears to be a by-pass retro fit type with pipe connection to the male thread and a banjo connction to the female thread.
These filters were available in different lengths but the connections were similar.
PostPosted: Sun Dec 04, 2011 12:15 pm    Post subject: Reply with quote
My Daimler 15 also has one of these on it, as Inglewood says, connected by pipes as a later addition.
kitisuru
PostPosted: Sun Dec 04, 2011 6:17 pm    Post subject: AC catalogue Reply with quote
Thanks Mike for suggesting the catalogue on eBay, I asked the seller and this reference is not in it unfortunately....
Churchill Johnson
PostPosted: Sun Dec 11, 2011 11:27 pm    Post subject: Reply with quote
Tried to do some more checking these filters are not for the Ford pop they use ZR1 same as a standard.
